Thursday, Jan 17, 2013 at 07:13
I'm not 100% sure about other brands . . . my longranger
tank uses the same sender unit, so it just sits on full until the
tank over the drive shaft empies down to original level . . . I get pretty much exactly 400km until it's down to full on the guage, then a bit more than normal capacity to yellow light.
I have tested it down to another 80km before filling up, not game to push it further.
Seems most times at fill up, I generally put in 115lt or so, have around 10lt left in
tank, but then the capacity might not be 100% accurate.
From when I was researching, other aftermarket tanks use the same sender unit and operate in the same way.
_
779264
