80 series L/C: Rough gear change at lower speed
Submitted: Tuesday, Jan 27, 2004 at 16:15
chenj3
Hi all Landcruiser Guru,
I bought a 1997 Landcruiser 5.4l petrol auto with 155K on the clock before Chrismas and discovered that the gear change at low speed is quite rough and sometimes I can feel a sudden kick with a click sound when gear change. This symptom becomes more obvious after a long trip and heavily loaded with
camping gear. One of my mates suggests that change the transmission oil normally solve this problem from his experience. I checked the transmission oil and the colour of transmission oil looks fine to me ( it is pink without any burnt sell). Can any Landcruiser expert please help me on this as I am not mechanical oriented. If transmission oil is the cause then should I send it to Toyota for oil change or I can do it by myself? any possible cause?
Any help is much appreciated.
Reply By: Kiwi Ray - Tuesday, Jan 27, 2004 at 16:44
I would change the oil and filter, the oils Iknow are red not pink. pink usualy means
water is present that will vaporise at high temp
hope this helps
ray
44489
Follow Up By: chenj3 - Tuesday, Jan 27, 2004 at 16:58
Kiwi Ray,
Thank you for your help. Is there a auto transmission oil filter ? I could NOT find. The problem is still there after I change the engine oil ( NOT transmission oil), I also discovered that the front console was quite warm ( maybe i should say hot) after long trip as my left leg can feel the warmth from front plastic console.
306675
Reply By: Kiwi Ray - Tuesday, Jan 27, 2004 at 17:09
The filter is inside the trans, you will need to drop the trans pan. Buy a new gasket first.
By front console do you meen the centre one
Do you have the radiator with the trans oil cooler built in?
All the Cruiser are a little different in NZ
Ray
44494
Follow Up By: chenj3 - Tuesday, Jan 27, 2004 at 17:28
Kiwi Ray,
I will check out the
Gregory's service manual for my Landcruiser ( bought one at Kmart for $22) and see if I can get more details for replacing the oil filter.
The console I mentioned is area where I change my auto gear and 2H/4L Lever. it is just next to my left lower leg.
My L/C has a built-in trans oil cooler.
I used to drive a Pajero petrol in
Hamilton, NZ for 4 years so I know the different models in NZ.
306677
Reply By: Member - DOZER- Wednesday, Jan 28, 2004 at 06:12
Gday
Common accross the range, general concensus on the cruiser site www.lcool.org is to use Castrol VMX-M oil to reduce.
wheredayathinkwer mike?
44583
Follow Up By: chenj3 - Wednesday, Jan 28, 2004 at 13:25
Thank you ! Dozer.
Is Castrol VMX-M used in Auto Transmission or Engine? why it can fix this? Thank you
306768
Thank you ! Dozer.
306769
Reply By: Member - Eskimo - Wednesday, Jan 28, 2004 at 11:08
geez where'd ya get a 5.4l
i want one too!Wow, am I cute! The extra long legs are built-in prevention against ducks disease. Great looks and a real goer. Doesnt waddle along like some.
44599
Follow Up By: chenj3 - Wednesday, Jan 28, 2004 at 13:30
Sorry for the typo. Eskimo
306770
Reply By: colin - Wednesday, Jan 28, 2004 at 11:55
I would take it to an automatic specailist and get them to do a full service which includes oil filter tighten bands and full check, if you take it to toyota this is what they do. Autos should be serviced once a year. Col
44605
Follow Up By: Wil - Wednesday, Jan 28, 2004 at 20:53
I agree with Colin. You should take it for a complete service. They have a machine to pump fresh trans oil thru and flush the torque convertor (you can't bleed them properly) which should improve gear change immensely.
306806
