Axle removal - Series 2 Landrover
Submitted: Wednesday, Jan 28, 2004 at 10:38
Justin
Hi guys,
I'm asking on behalf of a friend. He has a series 2 landrover and managed to break something. All symptoms point to a broken rear axle. He's attempted to remove the offending axle. One axle come out with no worries. The other side just wont budge. It will turn but it seems impossible to pull out. Any suggestions on why this would be happening. Is it possible the splines are damaged and are preventing it from being removed?
What would be the easiest way to get the axle out?
CHeers,
Justin
Reply By: Member - Ross - Wednesday, Jan 28, 2004 at 14:14
Probably broken part way along the spline at the diff end. May need to drop the diff as
well if it's jammed. Have you tried a decent weight puller??Fidei defensor
Rosco
44614
Follow Up By: Voxson (Adelaide) - Wednesday, Jan 28, 2004 at 14:17
Ross... Where are your pictures taken?___________________________________
Simpson trip 05/04 then turn left at
Birdsville to
Darwin via
Lawn Hill etc
306771
Follow Up By: Member - Ross - Wednesday, Jan 28, 2004 at 21:45
Vox me old mate, how's it going cobber?
Photos taken at a place called Levuka ... working cattle property come 4WD
park outside Wodenbong, just over the border from Qld in NSW.
Top spot. Went there on our first outing with a club we've recently joined. Haven't had occasion to join a club in the past but enjoyed it immensely.
If you've time would you check out my 2nd sat ph post as I'd welcome your comments.
CheersFidei defensor
Rosco
306818
