Wednesday, Mar 13, 2013 at 18:14
We have a misunderstanding. What the Sand Man was taking about and what I replied to did not have a shackle involved. He was talking about removing the tow hitch, inserting the eye of the snatch strap into the hole in the tow bar where the tow hitch goes, and using the same pin that holds the tow hitch in to go through the eye of the snatch strap. This pin is not rated it is just a piece of shaped steel rod designed to hold a tow hitch. In it normal function it cannot bend as the forces are in two
places on either side of the two hitch. To fail it would have to sheer in two
places. However if it is holding a snatch strap the force on the pin is in the middle of the pin between the sides of the tow hitch a situation for which it is not designed. This method has one major advantage in that there is no shackle involved so no possibility of a lump of iron flying through the air should the pin fail. A bent or broken pin is a hassle but much safer. It takes a huge force to bend a tow hitch pin let alone break it if you believe that you need these extreme forces to effect the recovery you should not be using a snatch strap but looking at other much safer methods.
Rated bow
shackles will, and have broken, but like Jeff I have never seen it because you would have to be an absolute moron to put
shackles under that much pressure.
Lastly my understanding is that a rated bow shackle is rated for a straight pull, which is where the two holes where the pin goes are under equal load. In Scott M's photo the other end of the strap could be higher or lower and the forces on the shackle would be equal on each side. However if the other end of the strap was to the side then the force on one side of the shackle will be greater than the other side. And the greater the angle the greater the difference in the forces. As we would normally operate
well within the rated capacities, small angles should be of little concern. I have seen rated snatch blocks with two pin holes so that the bow shackle can be horozontal as shown or the receiver turned 90 degrees so that the shackle is vertical, which would then mean it does not matter what the side angle of the pull is the shackle would be evenly loaded albeit a higher load as the angle increased away from a straight line. A thing to remember is that as the angle of the pull increases, and it does not matter if you are snatching or winching, the load on the equipment also increases and I would believe that the load would increase exponentially.
783766
