<span class="highlight">Solar</span> <span class="highlight">panel</span> purchase
Submitted: Friday, Mar 29, 2013 at 22:26
Member - graeme W (WA)
Just purchased a
panel off an ebay seller called smart-flash. His
panel rated at 140watts fits in the space next to one allready on top of my ute. As soon as possible after fitting i will
test it to see if the
panel returns the rated amps because it is smaller in size than the 125watt
panel that bit deals are selling. Unfortunately the bit deals
panel is to wide as they claim up to 10% more than the rated amps for their panels. I will be suprised if it is in fact 140watts given its smaller than all 120watt panels ive been able to find on the net but then again if it is it will be a bargain.
Cheers Graeme
Reply By: mike g2 - Saturday, Mar 30, 2013 at 01:03
Hi graeme, similar concept to you , but I bought a portable one from a traveller (4wd show)who sells at the shows, price was good. my accredited dealer( C/Van) and installer advised it wasnt really that suitable for a fixed install on van roof (as claimed) , it needed mod to suit...and wasnt the output claimed. I note newer panels are getting smaller. unless youve got the electronic
test eqpt with you its a case of 'trust me'.
like your photo by the fire-looks like a good set up as
MG.
507839
Follow Up By: Member - graeme W (WA) - Saturday, Mar 30, 2013 at 12:03
Hi Mike.
Its a good set up and thats why i tend to keep my 4x4s for 10years or more. Have room on top for another
panel which will give me at least 240watts so probibly wont have to use my 120watt folding
panel to keep both fridges going. Most of the time anyway. Did you move the reg on your
panel as they work best closer to the battery. Other than that no reason a folding
panel cant be used fixed allthough a single
panel would be more rigid.
Cheers Graeme.
785140
Reply By: Member - Ed C (QLD) - Saturday, Mar 30, 2013 at 02:40
G'day graeme,
You said > "I will be suprised if it is in fact 140watts given its smaller than all 120watt panels ive been able to find on the net but then again if it is it will be a bargain."
Alarm bells ringing right there... What are the
panel dimensions?
I'd suggest you get that testing done asap.. Indeed, If I'd bought a
panel, and had any doubts at all about the claimed output, I'd be doing the testing before doing any fitting... Just sayin'... (been there, done that ;-))
Would you kindly let us know the results of your tests, please...
I see the see the seller's location is
Sydney...
Wouldn't be Seven Hills,
Sydney by any chance ?
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
507841
Follow Up By: Member - graeme W (WA) - Saturday, Mar 30, 2013 at 11:23
Hi Ed. Not going in blind as such. Have been looking to add another
panel and ended up going for the best fit in the space. The ebay seller smart-flash advertises them as macht panels and maybe they are, time will tell. As i can
test it as soon as it arrives i will report back. The bit deals panels look to
test better than claimed but did not fit my space unfortunately. At $180 if it comes at 120watts its not bad value and thats what i thought it probibly would be. Any less however would be disappointing. They have got smaller over time my original
panel was a 64watt unisolar
panel that was bigger than most 120watt panels now. I guess
mine is a calculated risk.
Cheers Graeme.
785135
Follow Up By: Member - graeme W (WA) - Saturday, Mar 30, 2013 at 11:48
Hi Ed. Definitely
sydney but not sure where. His
feedback score has no negatives but then again not sure if most actually no what they are getting regards
solar. I have a spare mppt reg and a watt meter that that records everything as
well as a mate with the gear to tong the
panel as
well. The watt meters are good for anyone with a basic reg that cant record. With one each side of the reg you can record in and out and with two fridges one running as a freezer you can tell how many amps each unit uses. I bought
mine off
solar steve a very good seller but his panels are a bit dear now in comparison to the general market. With anderson plugs you can move the watt meter as required.
Cheers Graeme.
785137
Follow Up By: Member - graeme W (WA) - Saturday, Mar 30, 2013 at 12:11
Hi Ed.
1200 x 669
Cheers Graeme.
785142
Follow Up By: MEMBER - Darian, SA - Saturday, Mar 30, 2013 at 13:52
I thought I'd read a year or two back that Ebay now only publish favourable seller ratings from buyers....may be true...if so, the ratings system is technically
invalid.....still, a bit of hope, trust and some blind faith makes some purchases worth a go, considering the prices :-o).
785150
Reply By: Racey - Saturday, Mar 30, 2013 at 09:18
Check the voltage rating on the data plate; it may be 24 volt nominal system. The
panel voltage will be around 35-40 volts.
507846
Follow Up By: Member - graeme W (WA) - Saturday, Mar 30, 2013 at 11:34
Hi Racey. No its a 12volt
panel. The seller has no negative feed back in the last 12months and i will give a full report once tested.
Cheers Graeme.
785136
