Toyota Diesel Problem
Submitted: Wednesday, Apr 24, 2002 at 00:00
ThreadID: 1015 Views:2353 Replies:2 FollowUps:3
I have a 2H diesel (1982) Runs well except.
On going up hills the engine just dies. (looses power and then stops)
After a couple of tries to start to start it will go again for another 1-200 metres.
On the flat it seems to be OK even at 100Km/Hr
Reply By: Will - Wednesday, Apr 24, 2002 at 00:00
Peter,
The problem would be the fuel delivery pump, I am not familiar with that engine, most modern engines have the delivery pump in the injector pump but some old ones had a separate pump which in the new electronic versions is electric.
This pump is the one that brings the fuel from the tank to the injector pump.
It has probably lost suction capacity which is why it is OK on level but not OK uphills.
Take it to a diesel injection specialist.
Otherwise youcan check for air leaks from the pump back to the tank or even a blocked fuel filter.
Will
AnswerID: 3064
Follow Up By: Peter Johannsen - Thursday, Apr 25, 2002 at 00:00
Thanks for the assistance.
Armed with your thoughts and a "specialist's" estimate of $500 to $2,000
to remove and identify the problem in the pump, I started a search for
more finite symptoms.
After removing the fuel input to the pump and supplying fuel from a can,
the motor worked fine. I then eventually chased the problem to an almost
totally blocked fuel pickup in the tank. It seems that the pump was
cavitating when higher volumes were required, and the extra height to
lift the fuel when going up hill made all the difference. Unblocked with
a straight length of 1mm spring wire.
Thanks again
Peter johannsen
FollowupID: 1236
Reply By: Steve - Wednesday, Apr 24, 2002 at 00:00
Ahh...I had a 2H for years..wonderful motor. On the drivers side of the motor, near the front you will see the injector pump. Just behind this is a white plastic knurlled knob. This is the hand primer. Have a look for leaks around it. Also look for leaks around your fuel filters.
You may also have a loose fuel pick-up in your fuel tank.
AnswerID: 3068
Follow Up By: Will - Wednesday, Apr 24, 2002 at 00:00
Steve,
That hand pump is where the delivery pump is located...
FollowupID: 1207
Steve,
It wasn't there, but you sure helped me isolate it. It was the suction pipe inside the tank.
Regards,
FollowupID: 1237
