Saturday, Apr 13, 2013 at 22:06
"specifically about the voltage from 2 x parallel 150w 12v in shade dipping below the minimum for the mppt controller"
The Vmp (max power voltage) of 12V panels is typically around 18V, plus or minus. They vary a bit. Vmp is the max power voltage of the panels and the MPPT reg will try to hold the panels at that voltage and take the resulting current. That is Maximum Power Point Tracking. Your proposed MPPT reg will track the Vmp if the
panel voltage it sees is in the range 15V to 37V (in a 12V system). More sun, more amps. Less sun, fewer amps - but all at 18V. That's simplistic, but about how it works.
If you have two such panels in parallel the Vmp will be 18V. The MPPT reg will try to holding the combined
panel voltage at 18V. If the panels are equally lit, the amps into the reg will be double what one
panel could provide.
If one of those panels is shaded, then there are two possibilities.
1 If you have no blocking diodes the MPPT reg will try to hold the
panel voltage at Vmp, 18V. Some of the resulting current from the lit
panel will backfeed into the shaded
panel and be dispersed as heat in the shaded
panel. THE REMAINDER will go to the reg and charge the battery.
2 If you DO have blocking diodes the MPPT reg will try to hold the
panel voltage at Vmp, 18V. The lit
panel cannot backfeed to the shaded
panel, so ALL ITS OUTPUT will go to the reg and charge the battery. That is what you want.
Both of these scenarios assume that there is enough sun to allow the MPPT reg to keep the panels at their Vmp and take the resulting current.
If there is not enough sunlight on one or both panels to keep the voltage up to Vmp, then the system will be unable to track the maximum power point and will revert to a less efficient method. What that is depends on the design of the reg.
786578
