AnswerID: 45228 Submitted: Monday, Feb 02, 2004 at 21:35
Truckster (Vic)
replied:
There are 2 things you can do.
1) Add a second transfer case, which will give you multi ranges
HIGH HIGH
HIGH LOW
LOW HIGH
LOW LOW (you can put Marks or Rockhoppers in the second transfer case, giving you the Ultimate!!!)
2) add Marks or Rockhopper Gears, but this changes the whole of low range, 1st,2nd,Drive in Low range.
1st option
Advantage
You can still cruise along in low range as you do now.
Cheaper than Rockhoppers to buy ($1000 V $1200)
Disadvantage
Depending on your car, you can have viabration issues from the shorter tailshaft.
More expensive than Rockhoppers to install
2nd option
Advantage
Transforms the car, cheaper and I think better option.
Easily reversable if you want.
Disadvantage
You cant cruise along in low range as you do now on general firetrails with a few hills etc which would be annoying.
Food for thought.
Reply 3 of 5
