Sunday, Jun 23, 2013 at 09:39
Not necessarily so Bonz
If you look at the 7 pin
wiring in the articles section of this site you will see that it does not have a 12V lead from the battery when the ignition is turned off.
Pin 1 - Yellow - Left-hand turn indicator
Pin 2 - Black - Reversing signal
Pin 3 - White - Earth return
Pin 4 - Green - Right-hand turn indicator
Pin 5 - Blue - Service brakes
Pin 6 - Red - Stop lamps
Pin 7 - Brown - Rear lamps, clearance and side marker lamps
Where is the 12V feed in this standard mate.
792365
