<span class="highlight">Solar</span> <span class="highlight">Panel</span> Bargain or ....
Submitted: Wednesday, Jul 03, 2013 at 09:45
Member - bbuzz (NSW)
Hi all,
Is this
panel the best bargain going around?
http://www.ebay.com.au/itm/New-120w-Solar-Panel-Home-Power-Caravan-Camping-Generator-Battery-Charger/281128636006?_trksid=p11010.m2360&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D215%26meid%3D8794592543510870655%26pid%3D100080%26prg%3D1114%26rk%3D5%26sd%3D200930538932%26&ssPageName=ADME:B:WNA:AU:3160
Bill
Reply By: Member - Greg N (QLD) - Wednesday, Jul 03, 2013 at 10:20
bbuzz,
Still 3 days of bidding to go, but if you got it for that plus postage, it certainly would be a bargain.
514190
Reply By: Road Warrior - Wednesday, Jul 03, 2013 at 10:38
Hmm his
feedback is a bit unflattering:
"200w auction,
panel received measures only 160w, all 3 messages ignored, beware"
514193
Follow Up By: Member - Frank P (NSW) - Wednesday, Jul 03, 2013 at 17:12
There are two ways to express the wattage of
solar panels. One (NOCT) used by engineers, the other(SoC) by marketing types.
SoC is usually what is advertised - you'll only get about 70% of that.
More info in
this article, especially Part 2
793132
Follow Up By: Echucan Bob - Thursday, Jul 04, 2013 at 17:20
Feed back when I looked was 100%. It makes you wonder when that changes.
793219
Reply By: Rangiephil - Wednesday, Jul 03, 2013 at 11:15
It's a bit crook that there are no detailed specs on the ebay item.
I am very wary when someone lists a technical product without the means to
check whether the description matches the specs.
Regards Philip A
514195
Reply By: Glenn C5 - Wednesday, Jul 03, 2013 at 12:54
Yeh Good if you can get it for that price. Have a look when there is 5 mins to go. Might be a bit different then.
514203
Reply By: Member - Ed C (QLD) - Wednesday, Jul 03, 2013 at 14:27
Maybe, maybe not...........
Fair Trading Public Warning
I have no idea if this is one of George's many aliases, but looking at the
feedback (
check the neg!), I'd be willing to make a small wager that it is....
Personally, I wouldn't touch this one with a barge pole (YMMV)
Caveat Emptor!
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
514208
Reply By: Barbera72 - Wednesday, Jul 03, 2013 at 16:12
95.5%
feedback, 20 transactions: I would stay
well away from them.
514211
Reply By: allanw - Wednesday, Jul 03, 2013 at 22:58
If you feel like following up then ask what its dimensions are, then you can calculate its approximate output.
watts = Length x width x 0.15 /10
The 0.15 comes from the efficiency of a standard
solar panel. Length and width in cm.
514241
