some 84 troopcarrier questions
Submitted: Monday, Feb 09, 2004 at 17:17
ThreadID: 10399 Views:2454 Replies:3 FollowUps:2
We are currently setting up an 84 troopcarrier. Can anyone tell me if the roof gutters are OK to fit a roof rack and has anyone experienc ein fitting a wheel carrier?
Reply By: Member - Peter- Monday, Feb 09, 2004 at 18:49
On the old 40 series (which an 84 is) the roof gutters will handle a roof rack, the roof is bolted to the sides which are bolted to the main body.
You will have to find a tyre carrier from a later model swb (pipe type with the larger hinges and the vertical brace between the top and bottom tubes), reinforce the rear guard where it bolts on and also the latch mount. I did it on two 40 series troopies.
Or alternatively have some one make you a chassis mounted swingout carrier.
AnswerID: 46036
Follow Up By: Member - Wayne - Monday, Feb 09, 2004 at 19:56
I thought a 84 troopcarrier was a 70 series. Could be wrong.
Wayne
FollowupID: 307980
Follow Up By: Member - Peter- Monday, Feb 09, 2004 at 20:07
I had a late 11/84 HJ47 troopy, the 75 series came out in 85, although I have a mate who had a 'very' early 75 troopy which came from the factory with fixed side windows (no sliders) and its plate was either 12/84 or 1/85 (can't remember which).
FollowupID: 307981
Reply By: Willem - Monday, Feb 09, 2004 at 20:11
My mate has a FJ45 Troopie with a full length roof rack and wheel carrier and he carts all sorts of stuff on his roofrack. If you do fit a roofrack make sure you fit one with a continuous bottom rail made from flat iron where it fits on to the roof gutter so as to spread the load weight.
Cheers,Willem
Out on the Gibber
AnswerID: 46044
Reply By: Steve from Armidale - Tuesday, Feb 10, 2004 at 08:24
the 78 and 75 series troopys are rated to carry 300kgs on the roof.....not that I'd want to put that much up there!!!!
AnswerID: 46112
