<span class="highlight">Generator</span> Size
Submitted: Monday, Sep 30, 2013 at 09:23
Stephen H
Hi All,
Just bought a New Van with a Dometic Roof Mounted Air Conditioner. We intend on doing a fair bit of
Bush Camping. I was wondering What size
Generator I would need to run the Air Con. The Stats on the Compliance plate Are, Frequency Hz50, Normal Capacity KW3.2, Cooling1200Wt, Heating1300Wt..
Any help would be appreciated from you people who explore our wonderful country. Must keep the co-pilot happy.
Cheers Steve.
Reply By: Robert O - Monday, Sep 30, 2013 at 10:08
I have a Dometic B3000+ air conditioner and run it on a Honda 2.0 with a short 20amp lead (minimizes voltage drop) the Honda runs the AC but is under considerable load, fairly noisey if you are near other camps. One piece of advice, DON'T buy a cheap
generator.
518934
Reply By: Member - Rick P (NT) - Monday, Sep 30, 2013 at 10:33
The Honda eu20 will run your a.c but at full revs and it will use a 1lt of fuel an hour, so be prepared to get up in the middle of the night to re-fuel. Also make sure you turn off your battery charger and electric hot water system. With the cost of fuel now we found it just as cheap to stay in a Caravan Park for the night.
Rick P
518936
Reply By: Garry S3 - Monday, Sep 30, 2013 at 13:13
Air conditioner usually take more than 2 times the rated output for starting up. So you need one that can cope around 2.5kw surge. Honda 2.0 seems to be the only one that can take higher surge than its rating. However, there are portable
generator that goes up to 3kw and not as bulky as honda eu30i. I suggest looking into those as I have seen a few which was pretty impressive. If you have the extra bucks to spend, Honda will not let you down. Otherwise, you can get a reasonably good quality 3.5kW
generator for 40% of what a Honda EU20i woulda cost
518950
Reply By: stevie1947 - Monday, Sep 30, 2013 at 16:08
A Yamaha 2.4 will do the job and then some. Fantastic reliable unit.
518959
Reply By: rooster350 - Monday, Sep 30, 2013 at 19:22
If you really have to run a air conditioner all night when you go "camping" then in my opinion you should stay
home in your comfortable house and not annoy others with your noise....bad enough next door to one in a caravan clattering away with listening to one out in the bush...cheers
518968
Follow Up By: Bushranger1 - Monday, Sep 30, 2013 at 20:25
Hear hear!
Well put. Hardly could be called "Bush Camping"
Stu
798929
Follow Up By: Stephen H - Monday, Sep 30, 2013 at 21:35
Thanks for the advice you are entitled to your opinions. I have no intension of having a Air Con clattering away all night or annoying others with noise. I am only trying to make Life easier for my Wife who is not
well and wants to see our country before her time runs out not stay at
home in our Comfortable
Home. I've camped in the bush all my life and without Generators and Solar Panels and I respect it's beauty and Tranquillity.
Cheers Steve
798933
Follow Up By: stevie1947 - Tuesday, Oct 01, 2013 at 13:58
Good on u Stephen. You have every right to have a
generator to make you and your wife comfortable when conditions reguire it. Some people should keep their opinions to themselves if they can't contribute constructively.
Enjoy your travels.
Steve
798964
Follow Up By: Dennis Ellery - Tuesday, Oct 01, 2013 at 17:25
Gensets are a fact of life.
My wife wants her airconditioner and a microwave so we park in areas where gensets they are legal.
If you don’t like them – stay in a caravan park with mains power or locations where they are banned.
798987
Follow Up By: Bushranger1 - Tuesday, Oct 01, 2013 at 17:51
No Problem then.
I will just keep getting far away in the bush so I can listen to the birds & waterfalls instead.
Never stayed in Caravan parks & never will. Too much noise for my wife & I.
Still remember my friend coming away with us & saying it was so quiet he could hear his heart beat. Now that's nice & quiet I reckon & what getting away is all about.
Each to their own.
Stu
798991
Follow Up By: Dennis Ellery - Tuesday, Oct 01, 2013 at 20:27
Stu, I know where you are coming from.
I could live with a swag and a tent – but when on the road my policy is happy wife, happy life.
On hot days I turn the aircond and genset off about 4 o’clock in the afternoon - a 12 volt fan is used after that.
799002
Reply By: Dennis Ellery - Tuesday, Oct 01, 2013 at 17:33
The Honda 2 kva struggles on some caravan air conditioners.
A 2.4 kva Yamaha is a better choice for the larger van’s air conditioner’s
519026
