Hi guys,
Really hoping someone knows or could point me in the right direction, but it is a bit of a rare case i have, so i guess we'll just wait and see!
So without further ado;
I have a 150A/h AGM Battery that is running a LED light system and a few other bits and bobs (Phone chargers and the like) and it gets it's juice from a 120w Solar Panel. Everything's been running smooth and I did a lot of research to make sure that the system can run a few days without the sun if need be.
But now it's gotten to the stage where someone (could be the missus) has decided she wants to have some big power appliances. It seems the best way to run this would be with a 2Kva
Generator/Inverter (I have checked all the wattages and PF ratings to confirm everything is
well above what I'll need it to be). But then it got me thinking, if I have to go through all this effort to run her appliances, why not run my own?
So down the question, the appliances I want to run are 240v, but require very little current in the grand scheme, and should easily be able to run off the battery system that is already in place and if I don't have to run the
generator it would make my life a lot easier. So instead of buying a
generator/inverter AS
WELL as another inverter for the less power hungry 240v devices, can I use the battery I already have?
Correct me if I’m wrong but from my understanding the
Generator/Inverter produces power by:
Alternator produces 3 Phase --> Rectifier converts it to 12v --> Inverter converts to clean 240v (assuming pure sign wave)
Now knowing full
well that it would void the warranty can I attach the battery to the other side of the rectifier? So;
12v Battery -----^
This way (theoretically) I can just use the inverter that is built into the
generator inverter, and wouldn't need to go and buy ANOTHER inverter.
The main concern I have, and solution, is that when the
generator is running it would try and push 12v INTO the battery through those same leads that would supply the inverter when the
generator is off. But I figured worst case scenario I put a switch on those wires, best case, would it be as simple as a beefy Diode?
Sorry about the wall of text, I wanted to get enough information down to clearly explain what I was trying to do. I'm not expert in electricity (else I guess I would know the answer) but i'm not too clueless. So please don't be concerned with using the correct thickness wire, or the amount of amps that would be required etc, as I have a good idea of that already!
Thank you for any advice, assistance or answers you can provide!
