Big Wet and Big Trip
Submitted: Sunday, Feb 15, 2004 at 20:32
ThreadID: 10549 Views:2256 Replies:1 FollowUps:0
We are planning a trip Windorah to Innaminka via Planet Downs Arrabury Road then Bore track to Bollards lagoon amd on to Lyndhurst. Then Oodnadatta trak to Marla then Kulgera to Finke to Chambers Pillar to Dalhousie and across the Simpson.
We arrive Windorah around Easter Monday and cross the Simpson May 4 to May 9.
What are the chances of doing this trip given the current wet ground around the Cooper and Diamantina??
How long does it take to dry out?
Reply By: duncs - Sunday, Feb 15, 2004 at 21:45
David,
I would imagine that you would do most of that without problems at the time you are suggesting.
Current road information is available from Transport SA far north road report. Do a search under transport SA and it should show up. It won't tell you about all of what you want to do but is does cover most of the area and you should be able to work the rest out by looking at what info is there.
You could also contact the Birdsville Caravan Park. Ruth should be able to give good advice on what is happening. She does contribute to this forum from time to time.
Came through that area in October had a great time
Hope you do to
Duncs
AnswerID: 46815
