Stud Patterns
Submitted: Tuesday, Apr 30, 2002 at 00:00
ThreadID: 1057 Views:23470 Replies:6 FollowUps:2
Can anyone confirm the wheel stud pattern on a Nissan Patrol is the same a Toyota Cruiser/Hulux
True / False
Reply By: slunnie - Tuesday, Apr 30, 2002 at 00:00
Craig I have heard that, but have not done it. I have also heard that because of the centres the LC will go onto the Patrol but not the other way around. Wheel offsets are different between the two also, so a LC rim on a Patrol will make the track wider. I have been bush with someone who has done this with aftermarket LC wheels, but I would speak personally to someone who has done it.
AnswerID: 3236
Reply By: Nigel - Tuesday, Apr 30, 2002 at 00:00
The Patrol has the same 6 stud pattern as the 60/75/80 series cruiser and hilux (the 100 series went to a 5 stud pattern). You can physically fit a cruiser wheel to a nissan , but you'll have problems fitting a patrol wheel to a cruiser due to the different offset. Putting cruiser wheels on a patrol would give it a wider track, but may not be legal.
AnswerID: 3243
Follow Up By: Craig - Thursday, May 02, 2002 at 00:00
Thank Guy`s My main concern was I`m setting up a trailer and the only avail hubs are Toyota , My vehicle is a Nissan and just insuring the wheels are interchangable with regards to flats / spares.
FollowupID: 1331
Reply By: BRETT - Thursday, May 02, 2002 at 00:00
CRAIG I OWN A GU PATROL AND HAVE FITTED MY STANDARD SPARE WHEEL TO MY MATES 80SERIES CRUISER TO GET HIM OUT OF TROUBLE . WE MEASURED THE INNER OFF SET OF THE RIMS AND THERE WAS MINIMAL DIFFERENCE BETWEEN BOTH RIMS .WE TRAVELLED AT LEAST 400KM WITH OUT A PROBLEM.HOPE THIS HELPS YOU REGARDS BRETT
AnswerID: 3285
Reply By: Craig P - Friday, May 03, 2002 at 00:00
Craig,
You are being led astray with some of these answers to your question.
The stud pattern is the same as the Toyota but the hub centre on the Toyota is smaller. The Toyota wheels will not fit on your Nissan, the hub centre is too small. Nissan wheels will fit on your Toyota hubs though.This I know from practical experience, GU patrol and 80 series Toyota.
Craig P.
AnswerID: 3299
Follow Up By: Craig S - Friday, May 03, 2002 at 00:00
That`s great news , because I obtain some Hilux rims from a mate for my trailer,this could have caused me dramas out bush ( I would have said F#@&n Bugger ) if I got a couple of flats on the towing Vehicle ( Nissan).
FollowupID: 1341
Reply By: Mal Try - Wednesday, May 15, 2002 at 00:00
Craig, I have a 60 series LC. Nissan wheels fit on the the rear ( drum brakes) but foul the disc calipers on the front. Mal Try.
AnswerID: 3568
Reply By: n - Wednesday, Jun 26, 2002 at 00:00
your best shot 1/ go to a datsun dealer and talk to there spare parts departent or 2/ go to local car reckers and have a look for your self 3/ try your local machanic
AnswerID: 4436
