Low sulphur diesel
Submitted: Thursday, Feb 19, 2004 at 12:12
ThreadID: 10644 Views:1677 Replies:4 FollowUps:1
Anyone know if you can still make a claim for the damage done to fuel pump seals due to the low sulphur diesel?? If so who do I contact??
Reply By: donk - Thursday, Feb 19, 2004 at 12:34
Ray
The reason that the early pump seals & orings leak is that they are designed to swell slightly with traditional diesel but with the latest diesel this swelling doesn't occur & this is why they leak when this fuel is used
I don't think "damage" is the correct word to describe what has happened
Over a period of time all seals & orings will leak & what you have may be normal wear & tear not a fuel related problem
Regards Don
AnswerID: 47312
Reply By: Member - Oskar(Bris) - Thursday, Feb 19, 2004 at 14:36
I think the "statute of limitations" expired a couple of years ago.
Sorry, but check with your fuel supplier.
OskarThe real oskar
AnswerID: 47324
Reply By: Truckster (Vic) - Thursday, Feb 19, 2004 at 21:39
Not any more that was with BP at the time.
Contact yor bank as you will need lots of $$... :(
AnswerID: 47375
Reply By: Ray - Thursday, Feb 19, 2004 at 22:13
Thanks everyone, I thought that might have been the case. It was a mates car that is leaking, he was told anywhere between 1 and 2 thousand dollars. Yea go the diesel!! I was all for diesel at one stage but not so sure now. Between the added service costs and injector maintenance etc I'm not so sure it's the way to go. Still the verdict for that decission is still pending.
AnswerID: 47385
Follow Up By: colin - Saturday, Feb 21, 2004 at 10:43
sounds a bit rich for a leak, i had a leak from the low sulpur on a 92 GQ and it cost $150 to fix and BP refunded. Col
FollowupID: 309512
