a <span class="highlight">generator</span> question
Submitted: Monday, Mar 03, 2014 at 17:52
Lyall T
Hi all I am looking to buy a
generator and charger to recharge a 60ah battery that runs my lecky 34 lb watersnake. would like to be able charge a flat battery in about 6 hours . I don't have a lot of cash so looking for the budget option if there's one available.
Reply By: Member - Rosco from way back - Monday, Mar 03, 2014 at 18:23
As a suggestion ..... based upon your budgetary constraints, why not get a cheap 'n nasty genset from Bunnings et al. Couple this with a budget 240V battery charger and you're in business. The charger should sort out the possibly dodgy AC supply from the genny. But I think you'd be stretching the friendship to expect a 6 hour charge time.
527582
Follow Up By: Lyall T - Monday, Mar 03, 2014 at 18:48
Ah yes but what size genny and what size charger, will a 1.6 kw gen be enough to run a 14 amp charger for instance ???? or is it better to run a 10amp or am i talking crap ( extremely possible) looking at all this has really confused me and then theres solar ,aghhh!. but at this stage i'll just deal with genny's .
Cheers lt
810010
Follow Up By: Member - Rosco from way back - Monday, Mar 03, 2014 at 19:20
Well ........ as an example, I have an old (but still very good Honda 550/600W). That is adequate to run a budget charger, so I would suggest anything up to 1KVA, which is still quite cheap these days for a Chinese piece of gear.
810017
Follow Up By: Bushranger1 - Monday, Mar 03, 2014 at 19:22
I bought a cheapy 2 stroke Bunnings genny 3 years back & run a 16 amp Battery charger no probs.
Its a 2 stroke job & as long as you throw out the cheap & nasty spark plug & replace with NGK, use good quality 2 stroke oil in the mix & make sure you use fresh fuel you should be fine.
Mine has done
well over 1,000 hrs & it still starts & runs just fine.
Stu
810018
Follow Up By: Lyall T - Monday, Mar 03, 2014 at 20:38
What sort charge time are you getting.
810025
Follow Up By: Bushranger1 - Monday, Mar 03, 2014 at 20:49
I run a 130 AH battery & I run it down to about 50% state of charge.
The
generator is rated at 800W.
Takes about 6 to 7 hrs to get back up to full charge. Basically uses the whole tank of fuel in the gennie. I switch off the gennie before the tank is empty as the power can surge as the motor starves for fuel. This can cause damage to the 240V charger.
810027
Reply By: Dennis Ellery - Monday, Mar 03, 2014 at 19:22
Yes you can do it but it’s not cheap – the battery is the secrete.
Get yourself a low resistance AGM such as a Lifeline or an Optima.
You can charge these from deadflat to about 95% in two hours.
For a 60 or 70 ah - buy a cheap 40 amp battery charger and a 1 kva genset and you are in business.
I have a 150 ah Lifeline that I charge to about 95% in two hours with 3 cheap 40 amp chargers connected in parallel run from a 2.4 kva genset.
527588
Follow Up By: Lyall T - Monday, Mar 03, 2014 at 20:42
Thanks for the info all how much is a cheap 40 amp charger.
810026
Follow Up By: Dennis Ellery - Monday, Mar 03, 2014 at 23:18
The 40 amp chargers are common on ebay and will cost about $80.
Don’t use these on a normal 60ah battery as the charge rate is too high.
To absorb a charge quickly - you will need a low resistance type such as Lifeline, Optima or similar and these are expensive - around $300 to $400.
810041
Reply By: Travis22 - Monday, Mar 03, 2014 at 19:25
I use our Honda eu10i (1000w max) geni to supply a 15A ctek charger and when using Eco mode the geni will run at the minimum rpm while supplying the ctek. (In other words the 15A charger is only using 200-300w iirc at 230v).
IMO the built in 12V charger is junk, to get the 7-8A out of it the geni needs to be run at full speed (noisy) and it is unregulated so you need to monitor the battery while charging it and have a good idea when it's had enough. So I certainly recommend using the geni to power a dedicated 12V smart charger.
Travis.
527590
Reply By: Glenn C5 - Tuesday, Mar 04, 2014 at 06:59
Reply By: kiwicol - Tuesday, Mar 04, 2014 at 21:06
The best thing to do is buy a chri.ty
generator puts out a full 55 amps from a bosch automotive alternator, run by a ho.da 4 stroke small engine.
The price between $800 _ $1000.
All it does is charge a 12 volt battery.
Col.
527656
