Thursday, Mar 20, 2014 at 18:41
Hi There,
The difference between Auto and manual is the setup (apart from the price).
In terms of usage they are quite different.
An Auto system is roof mounted, and as such you need to bear this in mind for
parking, both at
home and also under tree's etc, you also need to remember that a satellite works only as long as the dish can see the satellite, tree's and other obstructions will prevent this, with a roof mounted unit this can mean the difference between
parking under the shade, and having to move to a unprotected area or turn the van/camper.
Having said that if money is not an obstacle they are obviously easier to use.
Also with the auto units you get what you pay for, and personally my money would be spent on a different unit, such as the German made intellisat autosat 2s.
In regards to manual units you need to remember a few things.
Small 60 cm dishes while they appear practical are not ideal, and do not work
well in central and northern area's, in fact people traveling to say
Broome find they cannot set them up and are forced to purchase a new 80 cm dish.
The mount, or tripod needs to be adjustable to enable you to get a level, no ground is the same, therefore a triangular base may work fine in a
caravan park with a nice level pad, will not work
well in a
free camping situation.
The manual setup consists of a dish, tripod and cable outside and would take at most 5 mins to setup, assuming you get a good satellite finder and dish, and get the angles correct you can find the satellite in less than one minute.
I can honestly park and setup in less than 3 mins.
The advantages of a manual setup is that you can move the dish further away from the van if required, this aids in finding levels and over coming any obstacles, and, you can park under shade should you wish to, unfortunately as someone else said in the rain you may choose not to set it up.
You can purchase a good manual setup for under $600.00.
For my money I'd much rather the thousands difference went towards my camping :)
I do work in the industry, and would be happy to help further if need be.
528740
Follow Up By: Member - Sheryl M - Thursday, Mar 20, 2014 at 20:15
Hi Chris
Thank you for your advice.
811371
