Sunday, Apr 06, 2014 at 17:44
Hi Geoff,
This does fit
well under Damien's header, but if it expands as it
well may, it may be better to start a new thread.
"1.My Engel states 2.5 A(max), so if it is cycling at 50%
that would be 1.25A per hour therefore 30A over a 24hr period?"
Your maths is indeed correct.
May I correct one thing though - many folk fall for this and it really irks after a while - An amp (A) is a measure of the rate of flow of electrical charge. ( It's actually a flow of one coulomb (6.241 x 10^18 electrons) per second, but let’s not get too hung up on the physics!) So --- we don't refer to amps per hour, any more than we'd refer to kph per hour. (I'm not being critical of you specifically, or aiming to prove I'm a boring pedant! but there are usually over 1000 people logged onto this site, and using incorrect expressions leads to lots of confusion. )
If your fridge is running about half the time, and draws 2.5A when running, then the average consumption is indeed 1.25A. The total demand we express in amphours (Ah), i.e. flow rate x time and so in 24 hours your fridge will call for 1.25 x 24 = 30 Ah.
Your TV - I suspect that it is running from a power adapter labelled 4.16A. If that's the case, then that's probably the maximum that the adapter can supply, rather than what the TV draws from it. I'd expect the TV to in fact draw less than the 4.16A, let's say 3A for 2 hours = 6 Ah.
The sat box. 2000mA = 2A. Again, I suspect the box itself draws less than that, probably about 1A rather than 2A, so in 2 hours that would be 2Ah.
The CPAP - I've recently been around the CPAP loop myself and am still looking for a human compatible system! The adapter is capable of delivering 90W at 24 volts. If it's the machine I think it is (Resmed), there is an alternative 60W adapter which will handle the pump plus humidifier, the 90W adapter being intended to also run a heated tube. If I'm right then you have some options - the pump itself will require a bit less than 30W, the humidifier (which can be turned off) will account for an extra 30W and the heated tube (also can be turned off?) another 30W. Each of those 30W loads corresponds with a current of 2.5A at 12 volts, plus 20% to account for inefficiencies in the inverter and power adapter. That comes to 3A, 6A or 9A. In 8 hours, 24, 48 or 72 Ah. The options to turn off the humidifier and heated tube are important!
Your 24 hour energy budget in rounded figures is
Fridge 30 Ah
TV and satbox 10 Ah
CPAP 25-75 Ah
plus a little (say 5 Ah) for lights, charging torches, phones, etc etc
If your battery is to have a decent life span it shouldn't be run down more than 2/3 of capacity and should be recharged asap. On that 2/3 basis, your 120Ah battery can deliver about 80 Ah. That's enough to handle the fridge and CPAP with humidifier but not heated tube.... and no TV!
How to recharge the battery? Under optimum conditions your 100W panel will provide almost 6 amps with your present PWM controller, or almost 7 amps with a MPPT controller. If we assume 7 hours of good sunshine per day, and keep the panel reasonably aimed at the sun, that's about 40 Ah per day with the PWM, about 10-15% more with an MPPT controller. You need at least 200W of
solar capacity to meet your minimum requirements. To have any flexibility you also need to at least double your 120 Ah battery capacity. (It may be possible to make use of the other (100Ah) battery.) You could also provide some charge to the batteries from you vehicle - the balance between
solar when stationary and alternator when driving needs further consideration.
As you obviously appreciate Geoff, there's a lot to go into here. Usually the fridge is the main consumer, but adding CPAP adds a whole new dimension. You do need more battery storage and more charging ability. Maybe you might consider the Lithium batteries referred to by Alistair, but $$$$......
Hope that helps
John | J and V
- Albert Einstein
812779
