100 series owners
Submitted: Monday, Feb 23, 2004 at 09:59
Wayne (NSW)
On a recent trip away with a 100 Series, the owner came to me saying he could not open the tail
gate either by the remote or key, the tail
gate was locked. Looking in the carago area some of his
camping gear had moved and was resting on the internal handle for the tail
gate. The lever for the lock is located on top of the handle and to lock the tail
gate the lever must be pushed in. The
camping gear was resting on the lever keeping it locked in. Turning the key would not unlock because of this. To compound the matter a cargo barrier was fitted so climbing in from the back was not an option. The 100 Series also doesn't have sliding windows in the back so after some manoeuvrering with a long jack handle from the back
seat, the
camping gear was pulled back and the tail
gate opened.
The 100 Series was fitted with a storage system which brought the
camping gear up to the same height as the lock. Having a storage system in the back all the time the owner was going to look at disconnect the internal locking system. He does'nt carry passengers in the back and having a cargo barrier in the back, exiting the vehicle via the tail
gate is not an option. The locking system still works on the tail
gate via the remote and the key, but the tail
gate can't be locked from the carago area
WayneAlways Out'N About
Reply By: Roachie - Monday, Feb 23, 2004 at 10:23
Wayne,
The GU Patrols had a similar problem initially and Nissan thewn changed the moulding so that there is now a protruding piece of plastic above and below the locking lug to prevent (in most cases) the lock being pushed in by gear.
It struck me that what the owner could have done would be to drive the vehicle at a "quick" speed and then do an emergency stop....hopefully all gear in the back would move forward an inch or 2 and take the pressure off the locking device.
Just a thought.
Roachie
47687
Follow Up By: Wayne (NSW) - Monday, Feb 23, 2004 at 10:44
Glad to see that not only Toyota have a design fault.
Looked at the crash stop idea but the
camping gear had fallen down and had wedge it self in. We had to move it side ways to release the lock.
Wayne.Always Out'N About
309670
Follow Up By: joc45 - Monday, Feb 23, 2004 at 12:20
Hey, Roachie,
Is this available from Nissan to fit the GU series I?
I have had the same problem when I have stowed a jerrycan in the back. S'pose I could make one.
Gerry
309683
Follow Up By: Roachie - Monday, Feb 23, 2004 at 12:33
Gerry,
Not sure whether Nissan would sell it....can't see any reason why not, but knowing Nissan it would probably mean mortgaging your kids..LOL.
Might be better to try the wreckers.
There's not much to it....it's just a small protrusion above and below the little lug that you push in to lock the door. In theory it would still be possible to have something narrow hit-up against the lug and pin the lock shut, but something "fat" like a gerry can wouldn't cause a problem.
Roachie
309684
Reply By: Mark R - Monday, Feb 23, 2004 at 13:59
Hey Roachie,
Let's get rid of that negative thinking - might to be better to mortgage the kids and look after the Patrol!
47716
Reply By: Wil - Monday, Feb 23, 2004 at 16:34
Should be simple. Just fabricate a small cover over the lock, somewhat like a missle triggle protector and you can flip it open to operate it.
Just a though..
Wil
47736
Reply By: jonsal - Wednesday, Feb 25, 2004 at 09:57
Same thing happened to us . (and also friends with their vehicle). After some acrobatics and tricky moves we finally gained entry to our wayback area. Have since taken the rocker lock bar out of the locking mechanism. Works a treat. No more risk of being locked out, but still able to lock with key, central lock.
47993
