Engel MT45FPD <span class="highlight">wiring</span> up to vehicle
Submitted: Monday, Apr 14, 2014 at 20:17
Scott T4
Hi everyone
I have just brought a Engel MT45FPD.
I was going to connect it up to a fuse panel that I have mains running to the deep cycle battery.
It is 6 or 8 mm cable.
The only things that I have running off the fuse panel is some LED lights.
The Engel book said that you should run straight from the battery to the Engel(a socket) & twist the cables together so you don't get radio interference .
The size of the cable depends on how long the run is.
Which way should I go.
Reply By: HKB Electronics - Monday, Apr 14, 2014 at 20:42
I assume you have heavier cable running form the isolator to the Deep cycle then
have run 8mm to the fuse box?
As long as the 8mm run is short you should be ok connecting the fridge to the fuse box.
As for the twisted cable, if Engel designed the fridge correctly you shouldn't get any electrical noise form the fridge!
I would try it as is, if noise is a problem then you'll have to try twisted cable.
Leigh
530560
Follow Up By: Scott T4 - Monday, Apr 14, 2014 at 20:50
I have the 8mm twin cable (+ has a 50 amp fuse at battery end)
going straight to the fuse panel (5 mtr run approx.)
I have a troopy bush camper.
813503
Follow Up By: HKB Electronics - Monday, Apr 14, 2014 at 22:23
The cable should be ok, even allowing for 19M (to & return) it is only about .1V drop at 4 amps.
The length of cable though might make a good antenna for RF noise, again try it and see, if it's a problem then you can always replace with a twisted pair later.
813512
Follow Up By: Scott T4 - Tuesday, Apr 15, 2014 at 06:26
Thanks for that HKB
813517
Follow Up By: HKB Electronics - Tuesday, Apr 15, 2014 at 10:24
No problem, if you do get RF noise you could also try using a ferrite RF trap (available at Jaycar) placed on the cable as close as possible to the fridge.
813530
