Cape York travel
Submitted: Monday, Apr 21, 2014 at 13:00
Member - Anne M (VIC)
Hi everyone,
Assuming the wet season has not made too much difference to the roads, will we be able to tow our Topaz van up the bypass roads to
Cape York? It is on the same
suspension as a t-van and we are towing with a troopie. It is a heavy rig but pretty bulletproof.
We are not even considering the Old Telegraph track before you ask! We will of course
check road conditions before we leave
Cooktown and we are experienced travellers off road.
Thanks in advance for your help.
Anni
Reply By: Member - Chris_K - Monday, Apr 21, 2014 at 14:22
Hi Anni
We towed our Quantum up to the Cape about 18 months ago. Assuming you get recent road information, you should be fine. We did let a little air out of both car and camper - which seemed to help. We checked out some of the OTT first (minus the camper) - and then used the bypass road for the bits we wanted to bypass. To get into
Twin Falls, you need to head up the OTT for a bit, but again, you should have no problems provided you take it easy! It was great fun.
Chris
530969
Reply By: Tony F8 - Monday, Apr 21, 2014 at 16:08
Anne M.
You haven't said when you plan to be up there, but as it stands at the present, the PDR is open with a 5t GVM limit, as I said in a previous post, the road is slushy north of
Coen and
Hann River R/H, but should not pose any problems for you.
Be wary of some of the dips, and generally drive to the side of them, work crews are out so also take care around them, you will easily find what channel the using, and what their up to.
Cheers and drive safe.
TonyF8
530972
Follow Up By: Member - Anne M (VIC) - Monday, Apr 21, 2014 at 20:32
Thanks TonyF8,
Sorry I meant to say that we will be up there in early June. We are in no hurry so we can take it gently. Thank you for your advice.
Anni
813996
