<span class="highlight">Solar</span> Output
Submitted: Sunday, May 18, 2014 at 13:57
evaredy
I would like to know how many amps a particular amount of
solar panels put out per hour.
I realize there are many variables but would like a rough indication.
Ok, so this is my setup.
Dmax has a 120 ah in
the tub, along with a Redarc BCDC 1240 (40amp), on the canopy roof, I have a Redarc 150W
solar panel. This is wired into the BCDC and also has an Anderson plug so I can plug it into the camper when needed.
The camper has a 120 ah battery along with a Redarc BMS unit, the camper has two 65W
solar panels fitted to the roof that tilt. I have had an extra Anderson plug fitted to the draw bar and wired into the BMS unit.
I also have a portable 120W
solar panel, I have had Anderson plugs fitted to it so I can bypass the regulator when needed.
So if I wanted to charge the camper battery, I already have the 2 x 65W panels, I can also plug in my 120W portable via an Anderson plug that is wired into the BMS unit. I can also plug in the 150W panel that is the on canopy via the same Anderson plug using a double adapter.
The cables for the portable and 150W are 6 b&s.
So this would give me a total of 400W of
solar, roughly how many amps would this give me per hour on a regular sunny day?
Reply By: Robin Miller - Sunday, May 18, 2014 at 14:16
Amps is an instanteous measurement Evaredy and it varies with how strong the sun is.
You probably want to know how many amp hours per day ends up back into the battery.
This depends on how many sunny hours at your location and strength of the sun for those hours which can also vary during the year.
Your 400w of potential
solar power probably delivers around 20 amps peak current hence 20AH for every hour of good strong sunlight shining on them.
532688
Reply By: The Bantam - Sunday, May 18, 2014 at 15:33
As you mentioned...how long is a piece of string.
The output of
solar pannels varies wildly depending on the time of year and the prevailing
solar radiation in that location.
If you are in allice springs in summer with a clear day...your pannels are probably capable of delivering their rated output
If you are in tasmania in the depths of winter..even on a clear day you may only get 20% of the rated output and then only an hour either side of
solar mid day.
in the higher lattitudes...kimberly,
Darwin Cairns you may get 10 hours hell may be 12 of good usefull electricity making sunshine on a clear day in summer...back to Tassy in winter and that 20% mignt last 2 hours and youy may be lucky enough to be getting some usefull of charge out to 6 hours.
A wise man will be generous in his design of a
solar system.
If you are realy interested in getting your head arround this subjact....goo off and buy one of Ray Rivers' books on
solar. they are easy to read and give you some realy good information like
solar radiation maps.
you will bless the day.
532695
Follow Up By: MEMBER - Darian, SA - Sunday, May 18, 2014 at 15:36
Collyn Rivers ?
815984
Follow Up By: Bob Y. - Qld - Monday, May 19, 2014 at 13:45
"Ray Rivers".......sounds like name of a blues or jazz singer :-)
816063
Reply By: MEMBER - Darian, SA - Sunday, May 18, 2014 at 15:52
Keep in mind that panel watt ratings are nominal (ideal conditions...cold and sunny). When you really need the power in warmer weather, 70% of the nominal is a probable max output from what will be extremely hot wafers under the glass.
532697
Follow Up By: Ross M - Sunday, May 18, 2014 at 18:29
Darian is correct, hot summer = less than full output in Alice cos they are "OT. Iwoud go with the ONLY 70% factor.
A cool full sun day in Autumn or Spring will beat any hot summer day every time.
My house system will at least make 2KW more in a cooler/shorter daylight period in early autumn and Late spring than a long hot day in summer.
Panels are panels.
816000
Follow Up By: Shaker - Tuesday, May 20, 2014 at 08:56
When we had our system installed, they said
Adelaide was the most
solar efficient city. We are in Victoria.
816103
Reply By: evaredy - Monday, May 19, 2014 at 11:23
Thanks for the replies.
I wouldn't have thought the panel would produce more when it was cooler.
532752
Follow Up By: RolaSolar - Friday, May 30, 2014 at 01:33
This is referred to as the temperature coefficient. All
solar panels power output starts to degrade as the temperature of the
solar panel goes over 25 degree C. This is because most
solar panel manufacturers
test the
solar power output at a panel temperature of 25 degree C.
If the outside air temperature is 25 degree C, the
solar panel could be as high as 50 degree C. By using the max power temperature coefficient on the
solar panels spec sheet the losses can be calculated.
For Example:
A typical crystalline
solar panel max power temperature coefficient is approx 0.4% / degree C. For this example for every degree that the
solar panel is above 25 degree C the
solar panel will have a power lose of 0.4%.
So even at a cool 25 degree C day the
solar panel would be around 50 degree C, giving you a power lose of 10%. So on a typical hot summer day at 40 degree C the power lose would be closer to 20%. So on the hotter days all
solar panel will produce less
solar power than usual.
Amorphous modules generally have a temperature coefficient of approx 0.2% / degree C which is half of a typical crystalline
solar panel.
In Australia this is an important factor to consider but most resellers either don't have this information or even don't know what your talking about. It's even common not to find it listed on the
solar panel spec sheet.
Regards Dave G
816776
Follow Up By: evaredy - Friday, May 30, 2014 at 13:12
Thanks very much for the explanation, it really does get you thinking.
At least now I have some understanding of how it works.
816820
