landcruiser transfer case vacuum solenoids
Submitted: Thursday, Feb 26, 2004 at 13:12
ross
Ive purchased a 1HZ motor and gearbox,t/case out of a 96 HZJ75.
I have a FJ73 manual with the pushbutton 4x4.My new t/case still has the old manual shifter on the t/case .Does anyone know if I can transfer the vacuum solenoids over to work on the new t/case?
I know the manual selector is more reliable but I want it to look as factory as possible
Reply By: Bob Y. - Qld - Thursday, Feb 26, 2004 at 15:13
Ross,
Probably depends on the age of your FJ73. There was a change to transfer cases, but am unsure just when. Don't think it would be a major task to change over.
Dozer would be able to help, he's clued up on tojos.
hooroo...
48216
Reply By: ross - Thursday, Feb 26, 2004 at 15:44
Thanks Bob .Im still waiting for the engine gearbox to be lifted out so I havent been able to compare the 2 next to each other.
48218
Reply By: Rojac - Thursday, Feb 26, 2004 at 15:50
Ross
Just ou of curiosity what did that set you back.......if you dont want to reply just tell me to F... O...
I've a HJZ 75
48220
Follow Up By: ross - Thursday, Feb 26, 2004 at 16:35
Rojac it cost me $4k .The engine and gearbox has done 120k and the t/case is supposed to be new and unused.We'll see!
I also got the starter,alternator, clutch, fuel filters,complete exhaust , belts,pulleys hoses and anything else that I can use.
The previous owner bought the engine for a planned camper and trip around oz but run out of time and space.
310115
Reply By: Rojac - Thursday, Feb 26, 2004 at 17:25
Ross
Thanx
48229
Reply By: Member - DOZER- Friday, Feb 27, 2004 at 08:38
Gday
You should be able to swap them over. The same transfer is used in the 1hz 75 as in your 73.
Andrewwheredayathinkwer mike?
48326
Follow Up By: ross - Friday, Feb 27, 2004 at 22:31
Thanks Andrew. The general consensus lies in that direction from others I have spoken to as
I will post my findings in the near future
310300
