Flags
Submitted: Friday, Feb 27, 2004 at 15:24
paul2.8d
Being a newcomer to 4 wheel driving, im wondering if anyone could tell me the reason for high flags on the front of some forbies ive seen around
sand dunes, im presuming its for safety to be seen by other fwd's on approaching peaks of dunes etc. is this correct?
Thanks Paul......... (Hooked on Stokton)
Reply By: fozzy - Friday, Feb 27, 2004 at 15:29
correct-use on dunes etc to see other approaching vehicle-ie when both coming up in op directions usually all you can see at top is sky.flags can make it a bit easier to see oncoming traffic ie in simpson dessert.usually connect to top of cb/uhf aerial
48400
Follow Up By: paul2.8d - Friday, Feb 27, 2004 at 15:33
I thought so, was also thinking it was a club thing..............Thanks Paul
310235
Reply By: Wayne (NSW) - Friday, Feb 27, 2004 at 15:30
Yes
WayneAlways Out'N About
48401
Reply By: Phil G - Friday, Feb 27, 2004 at 15:39
Usually mounted on front of vehicle/bullbar; 3.5 metres above the ground; need to be flexible so they wobble around;
orange flag is easily seen against blue sky. Aerials usually not high enough.
Very important for all
sand dune travel whether beach or desert to avoid head-on collisions at the top.
Not a club thing, just a safety thing, but clubs are usually very safety conscious.
48403
Follow Up By: macandjen - Friday, Feb 27, 2004 at 16:52
I'm going to
Robe at
Easter - can anyone point me to a place to get one of these? Eastern suburbs of
Melbourne.
310245
Follow Up By: Davoe - Friday, Feb 27, 2004 at 17:33
Try safety products shops as they are used by alot of mining companys
310255
Follow Up By: theratt - Friday, Feb 27, 2004 at 18:40
ARB stock them
310258
Follow Up By: Brian - Saturday, Feb 28, 2004 at 00:45
length of PVC pipe tied to bullbar and flag!
They also use them on
mine sites!!
Brian
310322
Reply By: Voxson (Adelaide) - Friday, Feb 27, 2004 at 17:16
Blank surf rod with a flag on top___________________________________
Simpson trip 05/04 then turn left at
Birdsville to
Darwin via
Lawn Hill etc
48420
Follow Up By: Member - Peter [SA] - Friday, Feb 27, 2004 at 19:44
And watch it snap when you hit some overgrown scrub!!!!
Better to buy the proper one to start with and be done with it.
Cheers Peter.
310264
Reply By: Member - Luxoluk - Friday, Feb 27, 2004 at 21:49
You may get one at Bunnings etc. Piece of 1/2" electrical conduit and mount to bullbar. I slip
mine into a 6" piece of pipe that bolts into the CB bracket and wrap a bit of 100mph tape to hold it in. Old piece of
orange material affixed to top and bob's ya.....It flexes under trees, its all
orange, can be disassembled into 2 sections, can be used to get the footy outa the tree, sword fight with the kids, disposable and cheap, in my opinion of course...! CheersButcher Country Track - Vic
48459
Follow Up By: Phil G - Saturday, Feb 28, 2004 at 00:40
I do the same, but use the 20mm
orange electrical conduit and put a rod of dowel up the middle to reinforce the lower metre or so. It slots straight into a piece of 25mm RHS steel or like you say, tape it to the bullbar. I also make it 2 piece, but reinforce this join with duct tape.
310319
Reply By: Phil P - Saturday, Feb 28, 2004 at 18:36
Extendable telescopic fishing rod is a cheap alternative - less than $20
48550
Reply By: fozzy - Monday, Mar 01, 2004 at 08:01
purchase from bicycle
shop
48713
