Engel fridge power
Submitted: Tuesday, Jul 29, 2014 at 22:17
duck
Do all engel fridges work on 12 & 24 volts by just pluging into power socket car 12v or truck 24v?
Reply By: Member - Stephen L (Clare SA) - Tuesday, Jul 29, 2014 at 22:31
Hi Duck
The short answer is yes.
It is advisable to unscrew the 12v plug on the end and use one of their othere fittings that are available.
536825
Follow Up By: Ross M - Wednesday, Jul 30, 2014 at 08:56
What about the Engels which were never marketed as being 12v &24v and only ever mentioned as 12v. ie pre fan models.
Are they also 24v compatible?
I have one which is 20years old and have never noticed any info relating to 24v.
821053
Follow Up By: Member - Stephen L (Clare SA) - Wednesday, Jul 30, 2014 at 09:06
Ross
Your fridge will also be fine on 24 volts. All Engel fridges are all 12/24/240 volt compatible.
821055
Reply By: John and Regina M - Wednesday, Jul 30, 2014 at 13:01
It would be wise to, unless it is specified as also 24v, to just use it on 12v otherwise you may be in for a repair.
Have you tried the manufacturers? They may have more info available than this
forum.
536849
