Site Search
Section Image
Normal engine temp
Submitted: Monday, Mar 01, 2004 at 16:03
SteveW
Hi Guys,
I have an 86 4runner and im wondering what is the 'normal' temperature the engine should be running at, its got a temp gauge installed because the original one was hopeless, so now i know how hot it is running but i dont know if its running hot compared to what it should be.. its a 2.2p (carby) 4y engineany help would be appreciated
Steve
Advertisement
ThreadID: 10916 Replies: 1
Views: 469 FollowUps: 6
AnswerID: 48771   Submitted: Monday, Mar 01, 2004 at 16:53
Wayne (NSW) replied:
Steve,
Reguardless of what the normal temp is on your vehicle the temp gauge may show you a reading, say 120c. If on a hot day and you have just raced up a big hill the temp gauge should read higher, say 160c. It is really a comparision on the difference between normal and hot. If the needle goes right off the dial reguardless of what temp it is reading the motor is very hot, time to get out and lift the bonnet.
WayneAlways Out'N About
Reply 1 of 1
FollowupID: 310583   Submitted: Monday, Mar 01, 2004 at 18:14
Brett posted:
And face the vehicle INTO the breeze.
FollowUp 1 of 6
FollowupID: 310619   Submitted: Monday, Mar 01, 2004 at 21:18
Steve posted:
Hi Wayne,
you working the 4by show in syd this year, will have to pop alonb n say g'day...
cheers steve.
FollowUp 2 of 6
FollowupID: 310624   Submitted: Monday, Mar 01, 2004 at 21:30
Wayne (NSW) posted:
Steve,
I will be at the Darling Harbour 18-21 March and might be at the Rosehill 17- 25 April. The only reason I will not be at the Rosehill Show is if I have to go to the Victorian High Country for a week.
Hope to catch up with you soon.
FollowUp 3 of 6
FollowupID: 310628   Submitted: Monday, Mar 01, 2004 at 21:38
Martyn (WA) posted:
Wayne,
I think we've mixed up our C's with our F's, if the waters at 120 degrees C we're smokin.......... Depends what thermostat you've got in, the usual is around 83 degrees C for a petrol motor, I have a 73 degree C thermostat just in case, the air con also tends to reduce the radiators efficiency, like to be on the cooler side, prsonal preference that's all.Keep the shiny side up
FollowUp 4 of 6
FollowupID: 310637   Submitted: Monday, Mar 01, 2004 at 22:09
Wayne (NSW) posted:
Martyn,
The 73 degree C thermostat you have will open at 73C, the temperature of the fluid in the radiator gets well over 100C. Remember the radiator is under pressure and this raises the boiling point of the fluid.
I just picked those numbers out of my head as a comparision and not a true temperature.
FollowUp 5 of 6
FollowupID: 310764   Submitted: Tuesday, Mar 02, 2004 at 20:57
Martyn (WA) posted:
Wayne,
I understand the bit about raising the boiling point with pressure, this can also be done with addtives to decrease the purity of the water, to a point, if this is the case why does the average temp gauge not go above 120 degrees C? When the engine is at "normal temp" the temp gauge operates around the 80 to 85 degree mark with a 73 degree thermostat in which I would expect, I've also run an infra red temp gun over the header tanks, to measure the efficiency of the radiator, (I had some overheating issues with my diesel GQ this is why I went to extremes) and I couldn't get a reading anywhere near a hundred degrees C, thankfully. Don't get me wrong Wayne I'm not having a go I'm just interested, the pressure cap on my GQ was around the 13 psi I think, and I'm not sure how many degrees 1 psi raises the boiling point either for that matter.
The problem with my GQ was the filler neck depth it was shorter than standard so the pressure cap was increasing the pressure to I don't know how much, I know it was enough to blow the rows of tubes from oblong to round blocking the air flow and crushing the fins, everytime the engine cooled down the rows where sucked flat again, it was only the damage to the fins that gave the problem away. Really a big problem, someones solution was to put two jubilee clips on all the hoses so they stopped leaking. I bought a not genuine 3 core radiator when I installed a turbo (trying to do a job cheaply), in the end I got my original two core radiator re-cored (if there is such a word) and never had another problem.
FollowUp 6 of 6
 Page Sponsors
Phone: 1800 21 21 21
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
