Sagging Bum
Submitted: Monday, Aug 18, 2014 at 21:31
Member - Barry H (WA)
Hi all,
I am looking a bit saggy in the bum, er that is the Nissan Pathfinder is looking a bit saggy in the rear end, do I go with a set of Polyair bags, or bite the bullet and go with new springs, the tow is a Challenge Camper Trailer, I had Polyair bags in the Toyota, and they worked a treat, what to do?
Barry H
Reply By: Member - Rosco from way back - Monday, Aug 18, 2014 at 21:52
G'day Baz
Whilst I'm a great believer in airbags within coils. I'm equally of the opinion they should be helpers rather than required to do the job of
the springs.
Hence my opinion would be to sort
the springs out first, then add bags as an adjunct, should they be required.
537863
Reply By: Member - Barry H (WA) - Monday, Aug 18, 2014 at 21:59
Thanks Rosco,
I must admit that is what I did with the Toyota, so I guess I may as
well do the same thing with the Nissan.
Barry H
537864
Follow Up By: abqaiq - Monday, Aug 18, 2014 at 23:29
Maybe look at SUMO springs - nothing to adjust, nothing to
puncture! The KISS principle!
822110
Reply By: Batt's - Monday, Aug 18, 2014 at 23:31
New springs to late for air bags once they have sagged probably should get the front checked out as
well it could be sitting a bit lower as
well depending how many k's they're done.
537866
Reply By: John and Regina M - Tuesday, Aug 19, 2014 at 09:57
An attempt at humor?
537877
Follow Up By: Mudripper - Tuesday, Aug 19, 2014 at 12:04
Unlike yours
822118
Follow Up By: John and Regina M - Tuesday, Aug 19, 2014 at 17:27
U think my post was an attempt at humor? Sad.
822125
Follow Up By: Mudripper - Tuesday, Aug 19, 2014 at 20:11
Oh yes, I forgot - you have none. Sad.
822132
Reply By: Member - Broodie H3 - Tuesday, Aug 19, 2014 at 13:18
Hi Barry,
I have the Nissan ti 550 Pathfinder and I put the air bags on from new as we tow a 23 ft Roadstar, the air bags are a bit of a let down and if I we to do it again I would go with the spring up grade you will get a firmer ride but it will be beneficial in the long run, then I would look to see if the air bags were still warranted.
let me know how you get on with the change as I may still go and upgrade
the springs.
537885
Reply By: Peter T9 - Tuesday, Aug 19, 2014 at 17:11
I am going through this on my 100 series at the moment and have been strongly advised progressive heavier duty coils are the go.
Cost wise in my case coils are about $240 for the pair against $400 for the airbags plus fitting for either.
537891
Reply By: Member - Barry H (WA) - Tuesday, Aug 19, 2014 at 18:18
Thanks Guys,
I will go with the spring upgrade first, see how that goes, then maybe airbags if they are needed, I will keep you posted.
Barry H
537892
Reply By: DesF - Wednesday, Aug 20, 2014 at 19:17
My mate bought a 96 Pathfinder new and he tows a Millard van , even not towing with 4 people in it used to bottom out on lumpy roads. so we fitted progressive Kings rear springs and a set of Poly Airs , and when he sold it last year it was still good as gold,
Cheers Des.
537955
