<span class="highlight">Caravan</span> TV.
Submitted: Saturday, Sep 06, 2014 at 20:10
Member - 2517.
Brought a new TV for
caravan assumed it was a 12 volts when I went to installed it noticed the power supply is 19 volt is there a simple way around it,the van has 2 90amp batteries and 360 watt of solar could run off inverter (600 watt) of solar .
Reply By: cookie1 - Saturday, Sep 06, 2014 at 20:29
Reply By: MEMBER - Darian, SA - Saturday, Sep 06, 2014 at 20:30
One plan might be......Presuming you mean it 'requires' 19V, you can get laptop computer power supplies that convert 12v to various selectable voltages (including 19v...and they have a number of plug options too)....but you need to make sure the wattage is sufficient for the tv. Jaycar might be a good start.
538707
Reply By: HKB Electronics - Wednesday, Sep 10, 2014 at 13:25
Something like
this would do:
538902
