Reply By: Member - Scott M (NSW) - Monday, Sep 29, 2014 at 14:24
Drove down this about 2 weeks ago. Track was very good * except the last 20-30 odd k's into the Balcanoona turn off - some gnarly humps and creek beds - nothing to be worried about unless you hit them at speed
* usual caveat - conditions subject to change - ask again closer to your travel time....
PS. 1st time my group has seen a 40 series airborne ........
AnswerID: 539686
Follow Up By: Member - michael f qld - Tuesday, Sep 30, 2014 at 13:51
thankyou for the info
FollowupID: 824383
Reply By: The Landy - Monday, Sep 29, 2014 at 14:52
Arkaroola Resort have information on its website.
Arkaroola Weather
AnswerID: 539688
Follow Up By: Member - michael f qld - Tuesday, Sep 30, 2014 at 13:53
thanks,shall follow up.
FollowupID: 824384
Reply By: Les PK Ranger - Monday, Sep 29, 2014 at 15:33
2 ways you can go, via Lyndhurst, well 3 actually if you take a little detour.
Down the blacktop to Copley then east again to Arkaroola . . . option, do the back loop drive from just before Angapeena station, north to Umberatana and into Arkaroola from the west . . . depends on time you level of adventureousness :D
Take an extra day to do that, lots to see on the way, or do that one day out of Ark if staying there a while.
Other more direct route, and the road is quite good . . . turn south off the Strz at Mt Hopeless (abandoned) Station, south via Moolawatana to Balcanoona, then the usual road to Arkaroola.
Quite a nice drive.
AnswerID: 539690
Follow Up By: Member - Bigred13 - Sunday, Oct 12, 2014 at 20:55
Michael f,
Just did the trip ,Copley to Innaminka via Balcannoona ,and the roads were in good condition ,except Mt Hopless to Innaminka , terrible ,very little traffic ,but as others have said it gets hot in that region ,spoke to a truckie 80 klms south of Moomba and he said the pot holes were the worst he has seen ,he was weaving all over the road to try and avoid them .
FollowupID: 826062
Reply By: Les PK Ranger - Monday, Sep 29, 2014 at 15:37
Sorry Michael, forget your asking about weather . . . see this page Climate stats Arkaroola
Looking like averages of low 30's for Nov / Dec.
It's a dry heat, and if not used to it it does feel different to same temps in other climates.
AnswerID: 539691
Follow Up By: Member - michael f qld - Tuesday, Sep 30, 2014 at 13:57
thanks,i intended to turn south off strz. and head to Balcanoona.I had forgotten about the dry heat,good to be reminded.
FollowupID: 824387
Follow Up By: Sigmund - Tuesday, Sep 30, 2014 at 18:03
Just a heads-up: the first few hundred metres of the Balcanoona track are slow to drain / dry after rain. Can be boggy.
FollowupID: 824390
Reply By: Peter_n_Margaret - Tuesday, Sep 30, 2014 at 23:52
Mount Hopeless to Balcanoona is a good route.
In 2009 we came down the Strz on November 9th. The shade temperature was at least 50C and it was blowing a gale. A break down would not have been a nice experience.
OKA196 Motorhome
AnswerID: 539749
Follow Up By: Peter_n_Margaret - Wednesday, Oct 01, 2014 at 00:01
How good is your fridge & freezer and your vehicle cooling system? :)
OKA196 Motorhome
FollowupID: 824408
Follow Up By: Member - michael f qld - Thursday, Oct 09, 2014 at 17:37
thank you-well noted
FollowupID: 825895
Reply By: Member - VickiW - Wednesday, Oct 01, 2014 at 21:36
Hi Michael,
it will be warm but as others have said it is a dry heat which is a bit easier. We use Leigh Creek forecast as our guide for weather forecast but, as we have a bit of elevation, it is a few degrees cooler than Leigh Creek. In fact last summer over Christmas / NY we were cooler than Adelaide during that hot spell.
The pool will get plenty of use though!
Regards,
Vicki
AnswerID: 539777
thanks for the info
FollowupID: 825896
