Site Search
Section Image
Toyota Key info
Submitted: Wednesday, Mar 03, 2004 at 21:29
Member Eric
Came across some interesting info for all the 98 onwards Toyota Landcruiser & Prado owners , Member Nick K had to replace a ignition key due to wear and was instructed he had to replace imoboliser module . Cost $1500.00 , Through some contacts of mine we got around the problem but not withought major works . It is sujested that you get a spare key cut and coded before it wears out and cant turn the ignition barrel , this way they can order a key and code it in programe mode . If you cannot turn the ignition barrel with the master key it will not go into this mode and requiere either a new module or a Toyota repairer to remove barrel and manualy thry to do this . Most Toyo dealers will not even attemt to do this , so get a new key now and safe the headakeVenus Bay
ThreadID: 10979 Replies: 9
Views: 3164 FollowUps: 9
AnswerID: 49090   Submitted: Thursday, Mar 04, 2004 at 06:47
Rosco - Bris. replied:
On a more general note we had a key break in half in the Disco ignition a while back. Apart from being an almost total pain in the arse .... it didn't have the same level of security, the locksmith advised you should only use a key for about 3 years due to wear etc.Fidei defensor
Rosco
Reply 1 of 9
AnswerID: 49091   Submitted: Thursday, Mar 04, 2004 at 06:50
Member - Eskimo replied:
Eric, is the new key to become the master or is it the original and do we store the master for future use.
Do they have to be able to turn the ignition to be able to code the new key? Wow, am I cute! The extra long legs are built-in prevention against ducks disease. Great looks and a real goer. Doesnt waddle along like some.
Reply 2 of 9
FollowupID: 310944   Submitted: Thursday, Mar 04, 2004 at 08:39
Phil G posted:
Eskimo,
Theres a rundown of the remote programming technique and master key programming on
http://www.lcool.org/technical/90_series/90_series_technical.html
FollowUp 1 of 3
FollowupID: 310997   Submitted: Thursday, Mar 04, 2004 at 15:55
Member Eric posted:
it becomes a second master , and yes they need the igniton on with a master to go into program mode , hope this helps
Click Image to Enlarge
GO HARD OR GO HOME
Multi air bag Caddy
FollowUp 2 of 3
FollowupID: 311002   Submitted: Thursday, Mar 04, 2004 at 16:35
Member - Eskimo posted:
Its clearer than the muddy pcirure I had before
thanks Eric
FollowUp 3 of 3
AnswerID: 49096   Submitted: Thursday, Mar 04, 2004 at 08:37
Phil G replied:
Hi Eric,
Well done.
The 90s Prados came with two master (black) transponder keys, one non-master (grey) transponder keys and two remotes. I'd suggest that people keep one black key aside for that purpose and survive with the two others. But like you say, if they have lost a master, best get it replaced. Nick's problem was he only had one master to start with.
Another interesting thing was the transponder keys are sealed and have no battery, so they only fail if damaged.
I'd expect the keys to survive longer if remotes are used.
Reply 3 of 9
AnswerID: 49098   Submitted: Thursday, Mar 04, 2004 at 09:12
Member - Bernie. (Vic) replied:
Hi Eric
is this the order you do it ?
1 buy a blank from Toyota
2 locksmith to cut key
3 back to Toyota to recode new key.
CheersPrado TD Auto
Little Desert 11/03
Only a lady driver would do that
Reply 4 of 9
Activities Index
Melbourne & Yarra Valley Scenic Joyflight Melbourne & Yarra Valley Scenic Joyflight
Melbourne - VIC
Spread your wings over Melbourne starting from the beautiful Yarra Valley!
Thrill Seeker Aerobatic Flight - 30 mins Thrill Seeker Aerobatic Flight - 30 mins
Hunter Valley - NSW
Are you a thrill seeker?
Ripple Couples Massage and Day Spa Package Ripple Couples Massage and Day Spa Package
Brisbane - QLD
Indulge in a massage and day spa session with your partner.
Canoe and Kayak Day - Vic Canoe and Kayak Day - Vic
Melbourne - VIC
Have a fun day while gaining confidence and skills in a canoe or kayak on the Yarra River.
Book Now - Things To Do
AnswerID: 49108   Submitted: Thursday, Mar 04, 2004 at 10:22
Member - Nick K (VIC) replied:
Guys I suggest you do the following.
1) get a blank key from Toyota.
2) get the key number from Toyota if you don't have it.
3) go to a locksmith (not a shooping centre one) and get them to cut the new key from the key number not your sightly worn out key.
4) back to Toyota to re-code.
OR
1) go straight to locksmith (if you current key if functioning) and most good locksmiths can do the lot. They have key blanks and can re-code them for you.
My problem is I couldnt take the above road as my master (one only) stuffed up so I needed Toyota to do something but if you have a good working key get the locksmith to do the lot but make sure they cut the new key from the key number database not your original as this is worn. Keep the new master at home just incase. This applies to all new microchipped keys not just Toyota.
Anyway take it from someone that has been running around for two days you could save yourself the hassell by spending a couple of hundred now.
Also thanks to Eric for talking to much to alot of people. With his mates I saved money.
Reply 5 of 9
FollowupID: 310999   Submitted: Thursday, Mar 04, 2004 at 16:00
Member Eric posted:
they could do it withought changing anything , they just wont do it the B*stards ,It is because they cant be bothered removing the ignition barrel and manualy putting it in program mode
GO HARD OR GO HOME
Multi air bag Caddy
AnswerID: 49142   Submitted: Thursday, Mar 04, 2004 at 14:52
thomo replied:
I have just had the same problem with my 100 series,When i bought the car it only came with the secodary key no master key at all so i went to a lock smith who checked the key to see if it had a micro chip in it,it did so he said all i needed to do was get a knew key have it cut then take the car and the key to toyota and have the code put on the new key, tried that but toyota said they cant take the code of the secodary key so they sugested i take out the drivers side door lock the key code is stamped on there so i did that got the code went back to toyota then the head mechanic said he still cant put the code on the new key without the master key.Getting very angry by this stage.So know i have had to order a new ecu and start all over again.So i sugest to any one with these type of keys to get one cut and coded of your master know before it cost you a fortune.By the way toyota sell a new key for $99.00 plus cutting which cost $23.00 +$15.00 to put the code on ,i got a key from the locksmith for $56.00 and the ecu was $250.00
Reply 6 of 9
FollowupID: 311068   Submitted: Thursday, Mar 04, 2004 at 21:14
CraigQ posted:
Thommo,
I have the same problem as you, I only have the valet key and went and got one cut, then went to Toyota who told me the bad news.
Where did you get your ECU from?
Can you email me the details? my email is:
quinnyandmegan@iprimus.com.au
Thanks Craig
FollowUp 1 of 3
FollowupID: 311769   Submitted: Thursday, Mar 11, 2004 at 17:19
Talking to Toyota dealer (different one from where i purchased but where I now gett it serviced) today on hypothetical scenario....I have lost my keys ..what can be done?
1. Do you have the little tag with the key code....No!
2. Try your selling dealer to see if they recorded No....they did not.
3. We can remove a door lock and get code as its stamped on it. ????
Rang selling dealer and was told all of above except no 3. The final offer of help was ....get a new ECU, new keys as well and next time save a mater in a safe place!
What goes here?
can they get the code from door lock????
Any how I am getting new masters cut and into the safe they go.....
what was the code to the safe??????????????????????
FollowUp 2 of 3
FollowupID: 311796   Submitted: Thursday, Mar 11, 2004 at 19:16
thomo posted:
Hi eskimo they need the master key to transfer the code across to your new key they cant even use the secondary key even thou it has the code in it aswell.They have a machine they put the master key in to read the code of your key then they put your new key in after it and transfer the code across.I did all the things you have just done.Pain in the ass.
FollowUp 3 of 3
AnswerID: 49148   Submitted: Thursday, Mar 04, 2004 at 15:14
chrisfrd replied:
Of course, if you had a Nissan GU Patrol, you wouldn't have this problem!
THey use the Bosch transponder system, which only requires recoding using the Nissan MOC-2 ECU coding computer and the dealers smart-card.
You just buy the new key, have it cut, give it to the dealer who is supposed to check your ownership details, then proggs the key in from the MOC-2 unit.
Done!
Reply 7 of 9
FollowupID: 311003   Submitted: Thursday, Mar 04, 2004 at 16:36
if I didnt have a toyota Id have a nissan patrol....but thats not what I wanted so I got the toyota
FollowUp 1 of 2
FollowupID: 311047   Submitted: Thursday, Mar 04, 2004 at 19:46
thomo posted:
I think a couple of hundred for a key is better then about $7000.00 for a new motor.
FollowUp 2 of 2
AnswerID: 49196   Submitted: Thursday, Mar 04, 2004 at 20:26
murranji replied:
Had the same trouble..Key wore out at 110000kms ..98 100 R V toyota..Small metal tag on key ring was missing from previous Toyota Co. owner..Door trim off..Number found.$99 Key puchased cut from Toyota..Lots of trouble encoding new key but patience persisted as system has been changed according to Toyota mechanic..Lesson ..Keep your key number..Use grey key as much as possible..Keys wear out rapidly..Perhaps keyless locking is an advantage{mine is an R V model,central loking but not remote] to save key wear.
Reply 8 of 9
AnswerID: 49363   Submitted: Saturday, Mar 06, 2004 at 12:11
prado95 replied:
Those looking for an immediate resolution (possibly away from civilisation) should consider how the "key transponderamplifier" & "transponder key computer" interconnect to the engine ecu on page G45, G44, G43 in the electrical wiring diagram supplement
http://groups.yahoo.com/group/90series
Reply 9 of 9
 Page Sponsors
Phone: 1800 21 21 21
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
