Daylight Running Lights.
Submitted: Wednesday, Oct 29, 2014 at 13:05
ThreadID: 109978 Views:2421 Replies:5 FollowUps:11
How does one wire up daylight running lights legally?
I have a pair of small ones and also would like to know about placement as the only place I can install them is on the radiator grill each side with about 450 mm between them.
They are only 8 led's each.
Cheers Dodg.
Reply By: garrycol - Wednesday, Oct 29, 2014 at 13:39
If they are only DRLs and form no other function, they should be wired to come on automatically when the ignition/engine comes on and switch off when headlights are turned on.
AnswerID: 541033
Follow Up By: Freshstart - Wednesday, Oct 29, 2014 at 14:12
Correct. Just the same as fog lights. On with parkers and off with headlights.
FollowupID: 826995
Follow Up By: garrycol - Wednesday, Oct 29, 2014 at 15:41
DRLs do not come on with parkers. They come on with ignition/and or engine start.
FollowupID: 827002
Follow Up By: Shaker - Wednesday, Oct 29, 2014 at 15:45
.... And unfortunately foglights don't go off when headlights are turned on!
FollowupID: 827003
Follow Up By: Freshstart - Wednesday, Oct 29, 2014 at 15:51
Yeah Shaker. They are supposed to be off if the headlights are on. But who bothers about minor points like that. Not many.
Garry. I think of it that way because it's easy. Off with the headlights. Not perfect but it's easy to remember.
FollowupID: 827004
Follow Up By: Nomadic Navara - Wednesday, Oct 29, 2014 at 17:13
Quote "Correct. Just the same as fog lights. On with parkers and off with headlights."
All fog lights must have a separate switch to switch them off. The quote below is from the Australian Road Rules, all states have now incorporated this particular clause into their own road rules.
Not only are they illegal to use at the wrong time they are annoying because of their poor control of their light spread. They are only used at the wrong time by posers, that's why they are referred to as wanker lights.
FollowupID: 827007
Follow Up By: Member - mechpete - Wednesday, Oct 29, 2014 at 18:08
wouldn,t it be nice if they just banned them , seeing as how the police don,t police the correct use of them an the wankers don,t
care how they annoy other motorists .
cheers mechpete
FollowupID: 827014
Reply By: Tim - Wednesday, Oct 29, 2014 at 15:48
NSW Legislation is
Road Transport (Veh Registration) Regulation.
Division 4 Daytime running lights
94 Daytime running lights
(1) A pair of daytime running lights may be fitted to a motor vehicle.
(2) A pair of daytime running lights fitted to a vehicle with 4 or more wheels must be fitted with the centre of each light:
(a) at least 600 millimetres from the centre of the other light, and
(b) not over 510 millimetres from the nearer side of the vehicle.
(3) However, a pair of daytime running lights fitted to a motor vehicle under 1300 millimetres wide may be fitted with the centre of each light not under 400 millimetres from the centre of the other light.
Location of daytime running lights on a vehicle
(4) When on, a daytime running light must:
(a) show a white or yellow light visible from the front of the vehicle, and
(b) not use over 25 watts power.
Note. The third edition ADRs only allow white daytime running lights.
(5) Daytime running lights must be wired so they are off when a headlight, except a headlight being used as a flashing signal, is on.
(6) For subclause (3), the width of a vehicle is measured disregarding any anti-skid device mounted on wheels, central tyre inflation systems, lights, mirrors, reflectors, signalling devices and tyre pressure gauges.
Tim
AnswerID: 541040
Reply By: Member - BRAD n JENNY - Wednesday, Oct 29, 2014 at 17:21
I just turn my headlights on so very simple
AnswerID: 541046
Follow Up By: John and Regina M - Wednesday, Oct 29, 2014 at 17:33
Hahaha
Yes as do I. Headlights. How boring. But effective.
DRL's are the equivalent of the old fog lights....wanker lights.
FollowupID: 827008
Follow Up By: garrycol - Wednesday, Oct 29, 2014 at 17:57
But if used correctly they will not blind you like fog lamps do at night at DRLs switch off when headlights come on.
The beauty of correctly set up DRLs is you do not have to worry about them - there is no need to switch them on or off - they do it all themselves.
Many OEM fits have them as dual function - during the day they are DRLs and at full brilliance but when you switch the parkers or lights on they then cut brilliance and became the parkers.
FollowupID: 827013
Follow Up By: deserter - Friday, Oct 31, 2014 at 12:57
I just the headlights in the on position so they simply are on when the ignition is on. Why add other lights ?
FollowupID: 827145
Follow Up By: Member - Laurie K (WA) - Friday, Oct 31, 2014 at 13:15
My headlights are wired into the ignition. Easy.
I do have a giggle, when people tell me that my headlights are on when I am idling ….. but if a globe blows, they tell me there is a blown globe ….not that the head lights are on. :-)
Laurie
FollowupID: 827148
Reply By: coonick - Friday, Oct 31, 2014 at 18:30
This post has been read by the moderation team and has been moderated due to a breach of The Foul Language Rule .
Forum Moderation Team
AnswerID: 541145
Reply By: TomH - Saturday, Nov 01, 2014 at 17:15
Well my VW has DRL.s and I wouldnt be without them. Wakes up all the w**kers who dont use their rear view mirrors.
Nine are LED and the headlights are always on auto so I dont worry about them.
Far better to be seen then not.
Canada for one country has a rule that sidelights are on permanently.
Perfectly sensible.
And as for w**ker lights they and their owner should be put off the road.
DRLS must as said above be fitted close to the edges of the vehicle NOT grouped in the centre or above the bonnet line.
AnswerID: 541184
