Wednesday, Dec 17, 2014 at 14:51
OK - I was probably a bit brief.... CTEK are multi-phase battery chargers and conditioners ... there are other brands, however they're fairly prominent.
They use 'intelligent' monitoring to asses the condition of the battery to perform both charge & discharge cycles to keep the battery conditioned correctly.
Irrespective of whether you have mains or not, your best option if the CT is in storage for long periods is to remove the battery and keep on permanent charge condition cycle with the CTEK or an equivalent.
Trust me on this, my 40 series spends long periods between trips under cover. Batteries always discharge and waste - virtually had to replace them b4 every trip. Keep it now permanently connected to the CTEK - batteries now last. Sorry, from experience, those solar charge things don't work.
829952
