ARB commercial bullbar (non-winch)
Submitted: Wednesday, Dec 17, 2014 at 16:01
Krooznalong
Anyone know whether it is possible to modify an ARB commercial bar (the non-winch version) to enable a winch to be fitted and if so what is required? Looking at a Runva winch.
Thanks in advance.
Reply By: Member - David Will (VIC) - Wednesday, Dec 17, 2014 at 16:44
Hi Krooznalong,
Why don't you contact ARB they made it and should be able to advise you on what you can do.
David.
543088
Follow Up By: AlbyNSW - Wednesday, Dec 17, 2014 at 18:33
Agree
Some have a winch reinforcing cradle
I read a thread recently of someone who modified a non winch bar resulting in a failure during a recovery
829972
Reply By: Jackolux - Wednesday, Dec 17, 2014 at 21:23
It probably can be done , we used to make our own winch bars years ago , never had one fail
Today with crumple zones and air bags it all very different , if your vehicle is a old model , no crumple zones or air bags it might be ok
I bet I know what ARB will say .
543100
Reply By: Krooznalong - Thursday, Dec 18, 2014 at 14:10
Thanks guys.
I had contacted ARB before posting here but had not at that stage received a reply.
Was hoping the only difference was a missing cradle that they could supply but no such luck. They suggested I could try an engineering place but said that cost would most likely be prohibitive.
So there goes my Christmas present!
543115
Follow Up By: Rod W - Thursday, Dec 18, 2014 at 17:16
So does your current bar have slots and/or cut outs and/or 4 bolt hole mounting pattern of 254mm x 114mm in behind the centre section of the bar.
830007
Follow Up By: Krooznalong - Thursday, Dec 18, 2014 at 17:23
Rod - it has the long narrow slot across the front. No other cutouts. Haven't looked for 4 bolt holes as I need to remove the protection plate underneath to do so - can't see in through the front slot.
830010
Reply By: Jackolux - Thursday, Dec 18, 2014 at 18:16
What vehicle is in on
543125
Follow Up By: Krooznalong - Friday, Dec 19, 2014 at 08:32
100 series Cruiser
830025
