A question for <span class="highlight">caravan</span> towers.
Submitted: Thursday, Jan 08, 2015 at 23:46
Member - peters500
Hello there,I had a Troopcarrier (2010 model V8) towing my Goldstream full height Off-Road van via a Treg hitch and enjoyed a wonderful experience.
Recently I sold the Troopy and replaced it with a Mazda BT50 twin cab ute .
Problem.Now, at or approaching 100 km/hr my van bobs from side to side - not a fish tail - but bouncing left to right. All tyres on car and van are at 40 psi.
I'm not happy. My thoughts are worn out shockers on the van.
Any other thoughts?
Thank you in anticipation of your worthy replies,
Regards PeterS.
Reply By: TomH - Friday, Jan 09, 2015 at 00:21
Wind vortex coming off a different shaped vehicle?????
543949
Reply By: mudbro2 - Friday, Jan 09, 2015 at 00:39
Is your van single or tandem axle? Maybe replace the shocks and see if it still happens. Do you have a canopy on the ute? It may be what TomH said about wind vortex. This could be a question to ask on one of the
caravan forums where all the members are caravaners.
543951
Follow Up By: baznpud (tassie) - Friday, Jan 09, 2015 at 17:17
If you look at the original post again, you will notice peters500 has the van for sale, not to sure why he bothered to ask the question.
baz
831102
Follow Up By: mudbro2 - Sunday, Jan 11, 2015 at 12:10
To baznpud. I have read the original post again but nowhere does it say he is selling the van. Not sure which post you were reading?
831171
Follow Up By: baznpud (tassie) - Sunday, Jan 11, 2015 at 12:27
mudbro2
Look at the bottom of the thread, "classifieds" van for sale.
baz
831173
Reply By: Russan - Friday, Jan 09, 2015 at 07:00
Could also
check wheel alignment on van
543955
Reply By: Erad - Friday, Jan 09, 2015 at 08:45
What about the loading of the van and tug? Are they similar?
Another thing to
check is the length from the centre of the rear axle on the tug to the tow hitch. The Mazda has a long overhang, and this may be creating a strong turning moment on the tug.
543960
Follow Up By: Lucko - Friday, Jan 09, 2015 at 09:22
That's exactly what I found with our Colorado, too far between axle and towball. Managed to shorten the hitch shank by 100mm, made sure we carried plenty of weight over the ute axle, reduced weight carried behind the van axles and reduced the van tyre pressures marginally. This helped no end.
From what I've read, this is a common issue with the increased popularity of utes towing caravans.
831074
Reply By: Member - wicket - Friday, Jan 09, 2015 at 10:05
Reply By: Member - peters500 - Friday, Jan 09, 2015 at 10:29
Thank you to all those who have replied - I'm onto it! Regards PeterS500.
543967
Reply By: Member - mark D18 - Friday, Jan 09, 2015 at 11:08
Did I read that right,
You sold the V8 troopy and brought a Mazda????
543972
Follow Up By: Member - Scott M (NSW) - Friday, Jan 09, 2015 at 11:29
mark +1 - that was my first reaction.....
831082
Follow Up By: Member - mark D18 - Friday, Jan 09, 2015 at 11:59
Scott
If you read it as
well it must be right.
Thought I was seeing things.
831084
Follow Up By: TomH - Friday, Jan 09, 2015 at 17:47
Always someone different
831105
Follow Up By: Slow one - Friday, Jan 09, 2015 at 21:11
Yep, spoke to Peter and he said he has traded up to a better vehicle.
831115
Reply By: Member - Will 76 Series - Friday, Jan 09, 2015 at 19:50
Why would you do that?
543995
Reply By: Member - peters500 - Friday, Jan 09, 2015 at 22:23
I just checked the replies to my query about towing. But I see instead that I need to apologise to two respondents.
To Mark D18 because I had the cheek to sell my Toyota and buy a Mazda. Unforgiveable!
And then Baznpud suggested I didn't even need to ask my question as I was selling the van.
Well to these two officious and self appointed moderators I say "mind your own effing business".
To all the others who considered my situation and offered their helpful replies - without comment - I say "thank you".
PeterS500.
544003
Follow Up By: Member - mark D18 - Friday, Jan 09, 2015 at 22:50
Sorry peter
Obviously A bit of a touchy subject .
831119
