jackaroo storage system
Submitted: Monday, Mar 08, 2004 at 09:45
jackablue
Any jack owners buit their own storage system? What's the best stuff to use? I want to be able to take it in & out regularly & what is the best way to fasten it down?
_____________________________
|_____________|______________|
Currently I have a proto type of this type, Fridge on the right on a slide & crates on the left, but it is too heavy to put in & out, doesn't fasten down & the base is the only thing that really comes off.
Jackablue
Reply By: Member - Wim (Bris) - Monday, Mar 08, 2004 at 10:27
Jackablue
I have a 2002 Jack. The storage system is my own design. Very simple and easy to remove.
Made from marine ply and tied down using turn buckles on the exisitng tie down points. Fridge is mounted on slide screwed to storage system.
Basically the false floor fitts up against the rear seats and is the width of the rear opening. Three sections of ply (on edge) form the uprights with timber battens for corner support.
If you want I can take some photos. Just send you email info.
49500
Follow Up By: jackablue - Monday, Mar 08, 2004 at 12:02
That would be great, my little picture drawing didn't turn out here. I have the fridge on the right with one shelf on the left with a couple of crates.
If you could Email w_o_z_@hotmail.com your photos that would be good.
311302
Reply By: Tim - Monday, Mar 08, 2004 at 13:17
Yeah Jacka I made a shelf for the back of
mine and finished it off, looks unreal but it won't come out easily-has fridge attachments too.
Let me know if you want pics of it and I'll send them to the email above.
Tim
49517
Follow Up By: jackablue - Monday, Mar 08, 2004 at 14:02
Thanks Tim, if you colud send the photos that would be great. The more ideas & info on what materials & fasteners used will help in construction.
311310
Reply By: Member -Bob & Lex (Sydney) - Monday, Mar 08, 2004 at 16:24
Made my original one from qubelock aluminum for the patrol & it worked great, just screwed alloy angle to frame & used existing tie down points, lined with masonite & carpet from clarke rubber. check out this link
link text
49538
Follow Up By: jackablue - Tuesday, Mar 09, 2004 at 09:29
Had thought of this too, thanks for the link.
311405
Follow Up By: macca - Tuesday, Mar 09, 2004 at 09:37
Bob & Lex
That Qubelock is the best and quite cheap too. I have used it for the back of the "Bitsaremissin" and the trailer. Light as and quick and easy to put your own spin on designs
311407
Follow Up By: jackablue - Friday, Mar 19, 2004 at 08:51
Bob I have a qubelock factory down the road, it looks pretty good. How did you secure your fridge slide to the queblock?.
312781
Follow Up By: Member -Bob & Lex (Sydney) - Saturday, Mar 20, 2004 at 10:34
jackablue, I cut 12 mm ply with corners notched to fit around uprights & fit to base frame, drill & insert captive nuts to bottom place slid on & bolt down. Attach ply to frame with hex head roofing screws.
312891
Reply By: Terryfied - Monday, Mar 08, 2004 at 21:48
Jackablue,I have made two storage systems for the jack,one is a drawer system and the other is basically a false floor that uses plastic
bins to slide in and out.
Both work
well ,although at times I found the plastic bin system easier to use because you can carry the
bins to where ever you need them.Both setups are bolted to the wheelarches where the fold down seats were situated.
I have played around with many ideas and will be more than happy to help if you want to bounce any ideas around,I can send photos if you require any.It definately helps to have some form of false floor or drawers.
Terry
49595
Follow Up By: jackablue - Tuesday, Mar 09, 2004 at 09:32
If you could send photos also, thanks. I have only had 1 email & that was a request from someone else wanting me to on forward the photos.
311406
Reply By: Terryfied - Tuesday, Mar 09, 2004 at 20:23
jackablue,use the member message system and send me your email address please and I will send photos direct.
Terry
49692
Follow Up By: jackablue - Wednesday, Mar 10, 2004 at 08:51
Can't use this function as it is for members only. My email address is above.
311539
Follow Up By: jackablue - Monday, Mar 15, 2004 at 11:02
Thanks for the pics Terry
312166
