100 series standard central locking
Submitted: Monday, Mar 08, 2004 at 23:36
Lachy
I have bought a central door locking kit fir my standard Cruiser. Has anyone installed one of these kits before and if so has succsseful was it? Also how hard is it to remove the door panels especially the window winder? Any advice would be appreciated
Reply By: cruiser100 - Monday, Mar 08, 2004 at 23:44
Have not installed the central locking unit but am looking into it, the inside door panels come off pretty easy, all you need is a piece of wire with a hook on the end and you can pull the clip off on the inside of the window winder (be careful as the spring clip can fly out and get lost). The little black triangle shape plastic cover on the inside of the side mirrors need to come off as
49617
Reply By: donk - Tuesday, Mar 09, 2004 at 00:54
An easy way to remove the winder handle is to get a piece if rag & slide it down between the handle & the door trim (if there is a disc between the handle & trim the rag has to go on the clip side of the disc which is normally between the disc & handle)
Hold both ends & pull down in the opposite direction from the handle & the rag should snag the ends of the clip & pull it off so you can remove the handle off the spline
To replace the handle push the clip all the way on & than push the handle over the tapered end of the spline & the clip will expand & than lock the handle back in place
Regards Don
49625
Reply By: fatz - Tuesday, Mar 09, 2004 at 09:23
Lachy,
Just fitted a central locking kit to my 100 series at the weekend. It's a bit trickey because the locks have a cable mechanism instead of the older style rods. The door panels are quite easy to remove and as described by others the window winder is also quite easy. The rods that are supplied with the kit you bought are probably too short, I went to Bunnings and bought some 3.2mm wire and made some new rods. Heres the trickey bit, I flattened the end of the wire and drilled a 2.5mm hole in it. I then removed the interior door handle and drilled a 5mm hole through it and attached the rod directly to the back of the door lock button on the inside. That's just a brief description of a trickey job! I also connected the whole lot up to a pushbutton remote. I seems to work a treat at the moment but time will tell how succesful it will be. I dont expect any issues as I spent a bit of time figureing out how to make it work and thinking through how to make it all work.If you are in
Sydney I'd be happy to show you what I did and lend a hand with yours. If not I could take some photos and send to you.
49630
Follow Up By: Lachy - Tuesday, Mar 09, 2004 at 09:39
Thanks I will give it a go. I am in
Perth. If you had some photos that would be a great help
311410
311411
Follow Up By: Lachy - Tuesday, Mar 09, 2004 at 09:40
311412
311413
311414
311415
311416
311417
Reply By: fatz - Tuesday, Mar 09, 2004 at 09:42
I'll take some tonight, do you have an e-mail address I can send them to?
49633
Follow Up By: Lachy - Tuesday, Mar 09, 2004 at 10:11
Thanks My email address is lpurton@vertel.com.au
311418
Reply By: Cruiser - Tuesday, Mar 09, 2004 at 23:30
Lachy,
Fitted one to my standard cruiser about 8 months ago. A bit tricky, but is perfectly do-able by the average person. Has worked fine and am very happy with it. I am in
Perth so if you need a guiding hand, drop me a line, orchard_david@hotmail.com.
Regard
49721
Follow Up By: Lachy - Wednesday, Mar 10, 2004 at 21:20
Thanks Dave. I hope to be doing
mine in the next couple of weeks. I am going to the Warrren this weekend and next is the Caravaning &
Camping show. So hopefully the weekend after that
311639
