Iridium update
Submitted: Tuesday, Mar 03, 2015 at 12:24
aussiedingo (River Rina)
G'day all, fyi
Important Notice: Your Pivotel Iridium Phone Settings
View this email in your browser
Dear Pivotel User,
As part of Iridium’s standard satellite network maintenance, Iridium must reset time settings on the Iridium Satellite Network. These time settings are scheduled to be reset on Wednesday 4th March, 2015 at 4:00am AEST (GMT+10).
For Pivotel Iridium satellite phone users, the reset will have no impact on service availability or on the ability to successfully complete calls or SMS messages. The only change you will notice is that the appearance of the date and time displayed on your Iridium phone will change to 29th December, 2007 at 5:26pm AEST (GMT+10) at the scheduled reset time and will progress from this time until your phone settings are adjusted.
To correct the time and date displayed on your Iridium satellite phone/s, you must update your phone settings after the network time settings are reset by Iridium on Wednesday 4th March.
Reply By: Sat Phone Sales - Thursday, Mar 05, 2015 at 21:57
Good of you to provide the "heads up"
dingo.
As mentioned there should be no issues for those provisioned "locally". There may be issues for those on non local
services / SIMS and older firmware levels.
If you experience problems please contact us and we'll try to assist. Please don't expect us to answer on the
forum, will my "xyz" service be affected? There are just too many variables involved. If you are experiencing issues after the epoch change please contact us directly.
Regards,
Kev
549479
Reply By: The Explorer - Saturday, Mar 07, 2015 at 13:06
Hello - from the internet...
Follow the instructions below to update the time settings of your Iridium 9505A, 9555 & Iridium Extreme due to the Iridium network time change/re-epoch. The Iridium GO! will handle the time change automatically.
Solution: Restore Time Settings for Iridium 9555 & Iridium Extreme
1. Dial *#99#2014051114235500#
2. Press the green key
3. Power handset off
4. Power handset on
5. Allow handset to register to the network
6. Handset will now display the correct time
Note: If the time displayed is incorrect,
check your time zone settings by proceeding with the following
7. Press Menu
8. Scroll to Setup and press Select
9. Scroll to Time & Date and press Select
10. Scroll to Select Time Zone and press Select
11. Choose the desired UTC time zone and press Select
12. Handset will now display the correct time
Solution: Restore Time Settings for Iridium 9505A
1. Press Menu
2. Scroll to Phone Setup and press OK
3. Scroll to Set Time and Date and press OK
4. Scroll to Set
Home Time + Date and press OK
5. Enter the current time in 24hr format and press OK
6. Enter the current date (dd/mm/yy) and press OK
7. Press and hold the C button to exit the menu
549549
