snorkel needed
Submitted: Tuesday, Mar 03, 2015 at 17:57
Member - Ian A7
Do I need a
snorkel to travel the
Gibb River road in August and do you recommend using one on a lap
Reply By: Member - Rosco from way back - Tuesday, Mar 03, 2015 at 18:02
G'day Ian
Probably handy for no other reason than increasing your chances of getting clean air to your engine .. as long as you are not tailgating anyone, in which case it'll make no difference.
From what you said of your planned trip, you are unlikely to encounter any water crossings of significant depth. However, should that not be the case, you could certainly add that to the plus side of the list.
546894
Reply By: Frank P (NSW) - Tuesday, Mar 03, 2015 at 18:03
Ian,
Depends on the season, I guess. When we were there in August 2009 there was no water crossing more than hub deep, so it wasn't necessary for water.
But I certainly think you need it for dust, and if you're doing a lap and intend driving on dirt then I think it's a must.
546895
Reply By: Member Andys Adventures - Tuesday, Mar 03, 2015 at 18:31
Yes for the dust, you won't have water problems at that time of year. And a new air cleaner as a spare.
546898
Reply By: Echucan Bob - Tuesday, Mar 03, 2015 at 18:43
Ian
You need a
snorkel, just like you need a Toyota. Its all about appearances.
PS I have a
snorkel.
546904
Follow Up By: Fab72 - Tuesday, Mar 03, 2015 at 19:07
....and Maxtrax in a prominently visual position too.
Fab.
834749
Follow Up By: OBJ - Tuesday, Mar 03, 2015 at 19:55
... and a
snorkel is a waste of money if your vehicle is not fitted with a Hi-Clone.
OBJ
834757
Follow Up By: Member - Kiwi_In_Aussie(Wagga) - Tuesday, Mar 03, 2015 at 20:22
and
check that the shackles are rated :-)
834764
Follow Up By: Crusier 91 - Wednesday, Mar 04, 2015 at 08:01
You can always fit a oil filled sock over the
snorkel ram. I use them and works like a charm. I also carry 3 spare socks for changeovers.
I've read that some diesel engines don't take kindly to them though.
834779
Follow Up By: OBJ - Wednesday, Mar 04, 2015 at 08:33
Cruiser 91.
I tried that and it sucked my leg into the
snorkel tube and I had to get recovery to get me out!
OBJ
834781
Follow Up By: Crusier 91 - Wednesday, Mar 04, 2015 at 12:51
OBJ,
The sock you are talking about and have used is not recommended.
The one I use is a ram opening cover and does not go into the the
snorkel.
834793
Reply By: Member - Ross N (NSW) - Tuesday, Mar 03, 2015 at 19:00
Can I assume we are talking about a diesel engine in your vehicle?
If so I think it wise and a conservative approach to fit a
snorkel but make sure it is waterproof at time of installation
546907
Reply By: pop2jocem - Tuesday, Mar 03, 2015 at 22:15
So Ian, are we talking about a 1964 Mini Minor you inherited as part of a deceased estate, a Landcruiser, Nissan Patrol, Jeep or Landrover. Maybe an ex army Unimog you bought at a recent disposal sale.
If it's the Mini, definitely, and a very good sump guard.
The Cruiser, Patrol, Jeep, Landy, in August very unlikely for water, good idea for dust as has been mentioned.
Unless you plan on travelling to The Cape as part of the "lap". Probably not a bad idea then.
The Mog, I would be quite confident in taking it as is.....LOL
Pop
546989
Follow Up By: TomH - Wednesday, Mar 04, 2015 at 09:35
His profile says its a Landcruiser 2002
834782
Follow Up By: pop2jocem - Wednesday, Mar 04, 2015 at 13:29
You're right Tom. I'm almost sure I clicked on the "profile" tab and it came up that me not being a member (yeah I know....shame) I couldn't view.
Obviously I clicked on the wrong bit hence my somewhat long winded reply.
Sorry, (:=))
834797
Reply By: Krooznalong - Wednesday, Mar 04, 2015 at 14:39
Do you NEED a
snorkel? No you don't NEED one - plenty of vehicles survive quite
well without them, despite what some might tell you.
My previous Cruisers (Middy and a couple of 80s) all survived the Cape,
Kimberley, Canning, High Country,
Simpson Desert,
Gunbarrel Highway etc without a
snorkel. And that included heaps of dust and some water crossings where it came up over the bonnet - in such cases one just take appropriate precautions.
My current Cruiser had one fitted when I bought it and it's still there. Makes the vehicle look "tougher".
If you have the money then having one saves worrying about dust & water and needing to take extra precautions at water crossings. If you do fit one make sure it is properly sealed - installers can be sloppy.
549415
Reply By: Alloy c/t - Wednesday, Mar 04, 2015 at 15:57
Short answer is NO ….
But then if you decide to go ahead and fit a
snorkel at least make sure that the joins are air / water proof and the air filter box water drain hose is sealed or that at least the one way valve is functional , also fitting a
snorkel and not fitting raised front and rear diff breathers kind of defeats the purpose of going into deeper water..
549421
Reply By: Member - Tony F8 - Wednesday, Mar 04, 2015 at 18:30
Three things diesel's thrive on, clean fuel, clean oil and clean air. Particulates at 1.8m are far less than at 1.2m and being forced under the bonnet by the radiator fan, and marginally cooler air the higher the intake is, and certainly as said make sure it is properly sealed against water ingress aswell.
549428
Reply By: fisho64 - Wednesday, Mar 04, 2015 at 22:00
probably dont need one, but when you find that you do, its too late.
As they are only a couple of hundred bucks now tops, why not just get one?
549435
Reply By: Outbackogre - Thursday, Mar 05, 2015 at 09:02
In my opinion, an equally important question in terms of water crossings is diff, transfer case and transmission breathers. I didn't bother with a
snorkel on my Pajero but I extended the breathers to high up on the fire wall.
549444
Reply By: Mark S (cns) - Thursday, Mar 05, 2015 at 10:05
A
snorkel does not deliver clean air to the engine, the air filter does. A
snorkel delivers cleaner air in dusty conditions to the air filter.
I carried a couple of spare air filters on my trip.
549449
