Hilux tiiming belt light
Submitted: Sunday, Mar 14, 2004 at 13:07
Squid
Does anyone know how to reset the timing belt warning light for 98 Hilux? Apparently the instrument cluster has to be removed but I have no further details as to how to proceed.
Thanks.
Reply By: Squid - Sunday, Mar 14, 2004 at 13:10
My above post should read 'for a 98 Hilux'. I do not have 98 Hilux's.
50291
Reply By: Steve Mc - Sunday, Mar 14, 2004 at 14:45
Squid my old hilux has a black plastic plug on the cluster face remove the plug and with something long & thin push the black shaft back in which is attached to your speedo numbers this will shut the light off until the next 100,000ks
Cheers steve
50294
Follow Up By: Squid - Sunday, Mar 14, 2004 at 16:10
Thanks Steve but my model does not have this plastic plug. I only wish it was that simple. For some reason Toyota have decided that it should be a complicated process.
Cheers Squid.
312101
Reply By: Member - Scooby (WA) - Monday, Mar 15, 2004 at 10:34
If your Hilux has a tacho (apparently some do not) and the timing belt light is on, remove the speedo and swap the tagged wire across to the empty screw hole nearby. If you change the belt before the light comes on there is a different procedure. I have a copy of the proceedure from the Toyota factory workshop manual.
To remove the speedo, the trim around the speedo has to be removed and then four screws to take out the cluster. The speedo cable has to be release from behind the cluster before it will come out.
Mr Toyota has made it harder to reset the light, maybe to stop people resetting the light and not changing the belt ie- If the vehicle was being sold.
If you need a copy of the proceedure use "Send Member Message" for my contact details.
Scooby
50367
Follow Up By: Squid - Tuesday, Mar 16, 2004 at 10:09
Thanks Scooby,
Have sent you a message.
Squid
312302
