AnswerID: 3552 Submitted: Wednesday, May 15, 2002 at 00:00
JohnF
replied:
Paul, we have a 40lt which has done a good job. The system you use, is just as important. For example, on trips of a few days, we just use it as a
fridge. But on longer trips, we use it as a freezer. We put in meat, sausages, etc, and also those thermo
ice cubes, that are refreezable. Then the day before, we select the items we want for thawing, put it in the esky, with the thermo
ice cubes, and presto, we've got thawed meat or whatever, each evening, as well as some
cold drinks.
Reply 4 of 7
FollowupID: 1437 Submitted:
Johnf posted:
They are actually called "Techni"
ice cubes. They come in sheets of 24 cubes, consisting of plastic on one side, and some kind of absorbent hesh on the other.
The way they work, is soak the sheet in water for a few hours. The hesh absorbs water, and they swell. then you freeze it.
When you put it in the esky, after some time the
ice turns to water, but the water stays in the hesh. You just re-freeze it to use it again. That's why it's perfect for an engel. I normally carry two or three sheets.
I think my wife bought them at K-Mart? or maybe Auto One? Not sure, we've had them a few years.
Hope this helps.
FollowUp 2 of 2
