Where to locate the inverter in vehicle
Submitted: Wednesday, Mar 31, 2004 at 23:49
ThreadID: 11720 Views:2072 Replies:2 FollowUps:3
Have a 7 seater gq and am about to buy an 600w inverter that l'll wire in to Aux battery.
Where would be a good location in the vehicle to place the inverter (ie from a safety & inverter longevity perspective).
Will be used partly for laptop small tv and battery charger for kids toys (actually I'll probably charge more battery toys then use it for anything else). Other main reason is for power tools (drill and grinder).
Reply By: Member - JohnR (Vic) - Thursday, Apr 01, 2004 at 05:56
Andrew, depends how inventive you are and where the spaces are. In my GU I have the inverter inside the back of the central armrest held in place with strong cable ties.
I had thought about putting it in a central overhead compartment out of the way of water but then you have the power leads to get there and unsightly leads away. You don't have any airbags either presumably so in the back of the glovebox area may be another option.
Don't forget the room to pack your vice, safety gear and workbench too ;)
AnswerID: 52746
Follow Up By: Member - Andrew K (WA) - Thursday, Apr 01, 2004 at 08:42
Yeah John, the vice, safety gear, workbench, welder, are in the trailer. You know you have to be ready for any situation. LOH
Glovebox, armrest good ideas
Thanks, Andrew
FollowupID: 314577
Thanks, Andrew
FollowupID: 314578
Follow Up By: Brian - Thursday, Apr 01, 2004 at 10:05
Just be aware of the need to have good ventilation for heat dissipation
Brian
FollowupID: 314587
Reply By: Member -Bob & Lex (Sydney) - Thursday, Apr 01, 2004 at 17:31
I put mine on the cargo barrier but I don't think you have one if it's still a 7 seater. What about one the side panel in the rear.
AnswerID: 52846
