AnswerID: 52788 Submitted: Thursday, Apr 01, 2004 at 11:43
Roachie
replied:
Bo,
What are the brand/s and models of the 2 radios? We may be able to tell from that which is which as far as UHF and AM/27meg CB is concerned. They are both classed as "Citizen Band" as far as I know; meaning that Joe-Public (ie: citizen) can use either without any worries.
UHF has largely taken over from the older 27meg/AM technology, although latter does have it's advantages as far as distances able to be achieved using "skip"....but that's a bit hit & miss and you wouldn't want to be relying on it.
With 2 radios fitted, you'd need to have a separate antenna for each one (they are different types for each too.)
I would expect that the roof-mounted one would be for the
UHF radio and even though it's only small, it probably has more "power" for transmit/receive that a larger aerial mounted on the bullbar. This is because a UHF antenna works better with a large "ground-plane" to assist send/receive messages. The roof acts like a satelite dish to gather signals and concentrate them on the antenna. I'd be leaving that one there.
If there is a base located on the bullbar, it maybe the location of the antenna for the 27meg CB. You'd need to get hold of a proper 27meg aerial and screw it on to see if it would work okay, but you may not get a response to any request for a radio check as no-one uses them much anymore.
Good luck
Roachie
Reply 1 of 6
