Wednesday, Apr 01, 2015 at 22:45
Hmmm, ok then, a fair bit is unknown, and the battery not the best for such work . . . you say you'll set fridge to 2C, yet you'll be using as a freezer ?
With mine, if I use it below a certain temp, it pumps more power into it, but I've only ever used it as a fridge.
Generally setting at -2C it is great for keeping things frozen from
home for the first few days, pack around the plate area, defrosts slowly, stretches out chicken etc a bit more.
At this setting the beer's perfectly chilled in the middle :)
My fridge averages 1.48 amps/hr in fridge mode and 1.64 amps/hr in freezer mode, and from memory my freezer mode is from setting - 4 or lower.
If you're not sure about how much power you'll need, maybe go up to 120w solar panel ?
You do know you'll need some sort of solar controller if using a standard solar panel ?
Unless it's like the Projecta where the controller is built in.
They also do a 120w panel see link
HERE . . .
You might be better hooking up a ctek250 controller, and running the car charge and solar panel charge into the battery using that, much more you can do with it later, larger or 2nd solar panel etc.
837452
