Do Not Overtake Signs
Submitted: Thursday, Apr 02, 2015 at 10:33
new boy
Reading the WA RAC mag yesterday there was a piece on the above signs the way I read it is if you wish to use 2 lanes to turn right or left a sign must be on each side of the turning vehicle. Right/Wrong
Reply By: TomH - Thursday, Apr 02, 2015 at 10:50
Wrong
Firstly they may only be fitted on rigs or vehicles over 7.5m long.
So a 4wd and a trailer would generally comply.
They must be made of certain material and certain dimensions.
Home made ones are not acceptable
The rules are here
https://www.infrastructure.gov.au/roads/vehicle_regulation/bulletin/pdf/vsb_12.pdf
Ignore the top part regarding weights and sizes and go to the bottom of the article
starting TURNING VEHICLE SIGNS
Also this one
http://www.towingguide.com.au/content/rear_marking_plates.html
A search on almost any vanning
forum will turn up a weeks reading about them
551915
Follow Up By: garrycol - Thursday, Apr 02, 2015 at 12:47
And you cannot use them as an excuse to deliberately cut corners unnecessarily. You often see this - plenty of room but still cut corners.
837470
Reply By: Slow one - Thursday, Apr 02, 2015 at 13:39
Mate,
you can just have one approved sign on the back of your trailer/caravan. The approved signs are different due to the many configurations of trailers. For example a car transporter/ skeletal and logging trailers and caravans as one size doesn't fit all.
On occasion with a small rig it may require 2 lanes when turning left from a 2 lane road into a narrow 1 lane road, then you may have to straddle.
Here is the relevant standard and you can scroll down to the installation requirements.
Standard for turning vehicle signs
551922
Follow Up By: TomH - Thursday, Apr 02, 2015 at 15:02
Which is the one I posted above.
You must also use the approved one which has a makers name and approval numbers on it. There is also a large strip with the words on it not shown in the standard
837477
Follow Up By: Slow one - Thursday, Apr 02, 2015 at 15:56
TomH,
they look different to me but I might have to put my glasses on.
I didn't realise it was a competition.
837480
Follow Up By: Motherhen - Thursday, Apr 02, 2015 at 19:11
TomH, your link did not work. Insert links using the "Insert Link" under the text box otherwise longer links will not work in full as a hyperlink. S
You are correct in adding that it must have right printing on it. Some sold on eBay do not have this. I got the correct ones from an eBay stockist.
837490
Follow Up By: TomH - Thursday, Apr 02, 2015 at 19:15
Sorry Mum, if you copy and paste it it will work Forgot about the length limit LOL
837491
