FollowupID: 314869 Submitted:
Sunday, Apr 04, 2004 at 07:35
Eric from Cape York Connections posted:
Graeme Bruce has summed it up pretty well with a good blind and well fitted this should be fine.
Is the air in take on the prado behind the headlight if you tarp up there with care this should be ok find out were your computer stuff is .
The rivers on the old track should not be to bad the pascoe on the french track could be a problem and getting into chilli could be hard work.
The hard work this year will be comming out of creeks very soft.
But with good rubber and correct tyre preasures you should be ok.
As per usual walk all creeks and plot a coarse i still walk most of them.
Some of the creeks look simple but you will be suprised when you walk them were you acctually have to drive to miss the holes.
Hope this helps
Eric
www.capeyorkconnections.com.au
 | Cape York Connections Member: Lapsed Membership |
