$30 dick smith power shower
Submitted: Monday, Apr 05, 2004 at 15:24
Michael
Hi all, Has anyone had a pump failure on those Dick smith, auto bahn, type $30 showers, the yellow one. Used
mine a few times and now the impeller is loose on the shaft and wont pump. Typical chinese junk i guess?? '
Reply By: flappan - Monday, Apr 05, 2004 at 15:47
Mines a bit hit and miss . . .
Was trying to use it with a Heat exchanger and gave up. Bought a proper pump instead.
53253
Reply By: Trol - Monday, Apr 05, 2004 at 15:47
Hi Michael,
I had one before installing a Glind and I found it to be a cheap alternative. I used
mine probably 6 weeks of the year, for 2 years and had no probs, take it back to Tricky Dicky's and see what they reckon, I guess for $30.00 you can't really complain, least if you bought another one, you'd have spare parts!
Good luck mate,
Trol.
53255
Follow Up By: Member - Mike (SA) - Monday, Apr 05, 2004 at 16:20
KMart have a good for around that price. Had no problems with
mine and economical on 4 'D' Cells.
Mike
314984
Reply By: Member - Peter (York) - Monday, Apr 05, 2004 at 16:33
Had the same type but it was blue ,,lasted 3 showers .
Water got in the seals , I have gone to the canvas bag on a rope so for no electrical problems
53260
Reply By: Patroleum - Monday, Apr 05, 2004 at 19:00
Also Had the same type but blue (Primus Labled). Failed first use.
Returned and bought "The Outback Shower" for $80.00. Uses a bilge pump and is fantastic.
53278
Follow Up By: Michael - Tuesday, Apr 06, 2004 at 09:11
Gday Greg, Where did you buy your Outback Shower from?
315059
Reply By: Dunedigger - Monday, Apr 05, 2004 at 20:48
Yep . . me toooo, Cost about $30.00 different color, used once, then stored for 18 months, completey stuffed, siezed . . .Probably should ee left hanging uo for a few days after use to ensure there is no moisture in the thing !
Just more junk . . . . .. . .. . .
Dunedigger
53298
Reply By: paul - Monday, Apr 05, 2004 at 21:13
yup, i used a few for my line marker made up from a pram and stuff for my football (soccer) field, they are total cr#p. Didn't want to use a bilge pump cause i wanted to keep at the around 9L per minute rate. Went to a caravan
shop and found the units that the cheap ones are based on. Look the same but a tad bigger and weigh twice as much. They hang them down into
water containers to provide low pressure through taps inside caravans. Cost about $65 but way better quality and i might hook one up for my own shower.
53304
Reply By: Truckster (Vic) - Monday, Apr 05, 2004 at 21:24
$30 and you expect it to last?
Seriously?
53306
Follow Up By: Roachie - Monday, Apr 05, 2004 at 22:14
Truckster,
You break me up mate.........LOLOLOL
When my Twine chucks the towel in, I reckon I might head off to Smithy's
shop and get hold of one of these yu-beaut $30- jobbies...
Roachie
315026
Reply By: rosco - Monday, Apr 05, 2004 at 23:43
Michael,
Been there done that and the pump failed. Plumbing is good for the amount of times I get to use it so went to www.bla.com.au and bought a $19.95 submersable marine pump and fitted that up. Works a treat.
Rosco
53326
Reply By: tim_s - Tuesday, Apr 06, 2004 at 08:17
Micheal
Had the same problem, but had to replace
mine in Armidale so it cost me $50!! I think it is slightly better quality though. I too will be going for the bilge pump. For ~$20-25 you can get one that outputs 450 gallon/hour (28l/min) compared to the standard pump that only does 4-6l/min. You can even use the hoses and shower head from the old one. Be warned though, you may want to put a restricter on teh flow or SWMBO will use ALOT more
water.
Tim
53345
Reply By: Michael - Tuesday, Apr 06, 2004 at 09:00
Hi Guys , thanks for your replies guys, I figured that might be the case, just junk. But you would think that after going to all that trouble to manufacture the complete thing, all the injection moulding tooling and the packaging, the moulding that they would spend a few cents more and possibly have a square shaft for the impeller instead of round to drive the impeller, and fix the other inherent faults,some so minor its really defies logic,,,,, but then,, it comes out of china where its probably assembled on someones kitchen table after dinner.... Thanks for the replies. Best regards Michael
Ps Truckster, when you really think about it, If you buy something, it really should perform for a reasonable time, we dont set the price. But i suppose we all know the reality, "YOU GET WHAT YOU PAY FOR".
53351
Follow Up By: Member - Liz- Tuesday, Apr 06, 2004 at 14:42
FANTASTIC! We just bought one via ebay,haven't even received it. Oh
well, you win some you lose some!
315090
Reply By: joc45 - Tuesday, Apr 06, 2004 at 17:35
My $25 Jaycar shower has been running fine now for about 6 years, including using it with sea
water. About 6 months ago, I took it apart and gave it a birthday; oiled the bearings, etc after the motor started chattering. Works a treat again.
Gerry
53436
Reply By: Patroleum - Tuesday, Apr 06, 2004 at 19:21
Micheal. We bought "The Outback Shower" from Nerang Disposals on the
Gold Coast Qld.
53450
Reply By: Member - Rohan K - Wednesday, Apr 07, 2004 at 16:14
I have the Jaycar one - same as joc. Used it twice and it stopped. Pulled it apart, the rotor was slipping. Fixed it (added a touch of Areldite for good measure) and now it works better than it did when I bought it.
If it does fail again, I'll go the "bilge" pump route and keep the rest as it's actually not that bad, quality-wise.
53560
Reply By: David N. - Thursday, Apr 08, 2004 at 07:18
We've had the $30 variety for about two or three years-
Lots if use and no problems.
53652
