Square battery posts
Submitted: Saturday, May 23, 2015 at 12:31
oz doc
HI. My partner has kindly bought me a 12v 12 ah sports battery for our upcoming trip. The only issue I have is that this particular battery has square shaped posts with holes in them. I'm wondering, other than alligator type clamps, what do I use to connect a wiring harness to these posts? I'd like to attach a wiring harness with 12 volt socket on the end. Thanks. doc.
Reply By: HKB Electronics - Saturday, May 23, 2015 at 13:03
Use normal eyelet terminals also an inline fuse holder close to the terminal as small
lead acid batteries or lithium etc can pack quite a punch if you short them.
554128
Follow Up By: Les - PK Ranger - Saturday, May 23, 2015 at 13:13
. . . using suitable size tank bolts / washers / nuts.
840111
Follow Up By: oz doc - Saturday, May 23, 2015 at 13:44
Thanks guys. I should probably try and put a picture up. The posts are recessed and of such a configuration that I cant pass a bolt from one side to the other. Because of the square profile I cant get a nut easily inside the post to receive a bolt end. I think the battery is intended for a motorcycle. I'm sure there is an obvious solution- my tired brain is not helping and nor is google. doc.
840112
Follow Up By: Shaker - Monday, May 25, 2015 at 16:05
If the battery was new, it should have been supplied with terminal bolts & the square nuts. You may need to go to battery supplier such as
Battery Power, they should be able to help.
840217
Reply By: Allan B (Member, SunCoast) - Saturday, May 23, 2015 at 16:45
Hi Doc,
Does the battery post look like this?.............
Term 1
If so, it is intended to have a square nut inserted into the terminal from the rectangular side opening and a bolt into it from the round hole like this..........
Term 2
The bare-ended cable is then inserted from the top and clamped under
the nut or the cable can be fitted with an 'eye' lug and clamped under the bolt head.
554133
Follow Up By: oz doc - Saturday, May 23, 2015 at 17:15
Hi Allan, I think you're on the money. Only the square opening on my terminals is not all that large. doc.
square end
top end
840115
Follow Up By: Allan B (Member, SunCoast) - Saturday, May 23, 2015 at 17:47
Doc, the battery should come complete with the bolts & nuts.
Perhaps ask the supplier?
A square nut of the correct size is required to prevent it turning in the terminal cavity. Also, I think the bolt can be alternatively fitted vertically through the top hole.
840117
Follow Up By: Hoyks - Sunday, May 24, 2015 at 10:08
Yep, it is a motorbike style battery, so there should be a square nut or hex nut to fit in the square hole and then you put a bolt through.
One trick is to stick a bit of cardboard under
the nut so it is pushed up to the underside of the terminal. If you don't, getting the bolt started can be a real pain.
Any battery
shop should have hardware to fit.
840145
Follow Up By: oz doc - Sunday, May 24, 2015 at 14:28
Ta for that. I was not looking forward to fluffing around with
the nut in such a small space.doc.
840156
Follow Up By: Member - Keith P (NSW) - Monday, May 25, 2015 at 18:26
Motorcycle batteries actually make good utility batteries.
Just remember to not flatten them properly..ie..use it for only about 60-75 % of its capacity...and then charge up again ASAP.
Another little tip is to have the vent open while charging...and then after charging and a time to cool down...plug the vent with an external blind cap while using to prevent spills if being moved about...remembering to always keep it up right.
HTH.
Cheers Keith
840229
