Frequencies on HF tapped antenna??
Submitted: Monday, May 25, 2015 at 13:28
wombat100
We have a tapped antenna and the 'labels' of the frequencies have fallen off or degenerated.
Description- It has 10 taps (not including the bottom pigtail tap)
The 2nd top tap from the top is 14977 and the 5th from the top is 8022.
All other taps are unidentifiable
It is brown in colour and about 1.9m long.
I have been in contact with Terlin giving description and info on the base- but they can't help.
Can anyone help me ??
Wombat100
Reply By: wombat100 - Monday, May 25, 2015 at 13:34
Just want to add:
The frequencies would be VKS737 and/or RFDS
554198
Follow Up By: Bob Y. - Qld - Monday, May 25, 2015 at 15:07
What are the frequencies on your transceiver, Wombat? Usually the taps on your aerial are a match for the freq. programmed on the t'ceiver.
And no doubt the RFDS frequencies would match the bases of the state you reside in. When we had to order new tapped antennas, all the frequencies would be noted on the invoice. You still got the invoice? :-)
840205
Follow Up By: Nomadic Navara - Monday, May 25, 2015 at 16:05
Bob, you are assuming that the antenna came sit a transceiver.
840216
Follow Up By: Bob Y. - Qld - Monday, May 25, 2015 at 18:14
Ha ha, yes I am, Peter.
One must make assumptions, because we only get half the story in many threads on the
forum.
840228
Reply By: Stu & "Bob" - Monday, May 25, 2015 at 16:44
If you were to contact your nearest radio/comms type
shop, and take the antenna to them, they should be able to connect it up to an antenna analyser (sp?) and identify the other frequencies.
HTH
554212
Follow Up By: wombat100 - Monday, May 25, 2015 at 16:59
Yea- I think thats gonna be the only way !!
840219
Follow Up By: MEMBER - Darian, SA - Monday, May 25, 2015 at 21:57
On their website, Terlin state that the frequency numbers are 'permanently engraved' into the body (so presumably one could always ID the taps, after years of use)....sigh.
840237
Follow Up By: The Explorer - Monday, May 25, 2015 at 22:44
Think older ones weren't (from memory labels imbedded under thin clear resin) ..plus not all are "Terlin".
840239
Reply By: aussiedingo (River Rina) - Tuesday, May 26, 2015 at 09:54
G'day wombat, I have the same antennae for my HF but I'm away 'till later in the week I will
check it then 'n see what
mine says & let you know, regards
dingo
554239
