mix it yourself chemicals for portable toilets
Submitted: Thursday, Apr 08, 2004 at 15:34
Rick Blaine
I have been told there are several recieps for
toilet chemicals that one can make ones self. The main ingredients i'm told are borax & concentrated disenfectant. Can one of the
Toilet litterate forumites shed any light on this delicate subject?
Reply By: Member -Bob & Lex (Sydney) - Thursday, Apr 08, 2004 at 16:50
We use the stuff in the white bottle from the
camping shop as it's supposed to be safe for the enviroment.
53704
Follow Up By: GO_OFFROAD - Friday, Apr 09, 2004 at 10:03
Maybe if you can mix it yourself, you could have it with ice, save adding it to the
toilet seperate....8-)
May make for a more pleasant "aroma" while in the car travelling too, save winding the window down.....8-)))
315430
Reply By: KiwiAngler - Thursday, Apr 08, 2004 at 16:57
Why would you want to?
The cost of the stuff isnt outrageous, you dont have to worry about exposure/storage/purchasing of chemicals and the formula constituents that you list are not what would be classed as 'environmentally friendly' as pointed out in previous reply.
Do you know what the 'home brew' versions do to the chemical
toilet itself?
At least with the 'store bought' stuff you have some idea of its compatability with your
toilet.
53706
Reply By: Phil - Thursday, Apr 08, 2004 at 20:42
Hi Rick
We have used a make up
toilet chemical for quite a while now and it works as good as a bought one. The ingredients are: 1 cup of Borax desolved, 1 cup of Pine o Clean and 1 cup of Cloudy Ammona all mixed together in 5 litres of
water.Works as good as anything you can buy and a lot cheaper as
53731
Follow Up By: David N. - Friday, Apr 09, 2004 at 07:00
Ditto Phil,
I use the same, works a treat and cheap. Got the recipe many years ago
315422
Reply By: raybates - Friday, Apr 09, 2004 at 14:43
Hi Phil,
I'm interested in your chemical mix for
toilets. How much do you put in a normal sized Porto Potti and is borax easily available?
Ray
53769
Follow Up By: bruce - Tuesday, Apr 13, 2004 at 19:04
Borax is readily available at any
supermarket..is cheap..but make sure you disolve it properly..same for cloudy ammonia..cheap...and pine-o-clean..been around for years..being so cheap to make , we use about a cup full per
tank...cheers
315715
Reply By: Rick Blaine - Friday, Apr 09, 2004 at 15:24
Yes Ray.. what is the concentration you use?
53773
Reply By: raybates - Sunday, Apr 11, 2004 at 00:03
Hi Rick. I use 50ml per fill
53858
